    Jun 2011
    Question need to rest speed control
    so my button keeps getting stuck, i fixed that but now i have only steering i cant remember the code to reset it. does anyone know it?
    Virginia Beach, VA
    112
    reset for slash model using TQ 2.4 GHz Tx
    Tx- Off , HOLD Menu and Set , Turn Tx- ON, RELEASE Menu ans Set -> RED LED BLINKS , Press Set -> settings will clear, LED will turn solid green.
    Then do this...
    VXL-3s Set UP programming.
    1.) Connect battery
    2.)turn on Tx
    3.)Press and hold EZ start button on ESC. LED will turn from green to red. release button.
    4.)when the LED blinks RED ONCE, pull the throttle trigger to the full throttle position and hold it there.
    5.) when the LED blinks RED TWICE, push the throttle trigger to the full reverse position and hold it there.
    6.)when the LED blinks green once then the reprogramming is complete. the LED will go either red or green if LVC is Active or not.
    TRY this. Good luck , its from the manual.
    Jun 2011
    thanks that helps a lot
