    Jul 2010
    438
    new supports any good?
    hey all my revo is nearly all back to life after breaking a rear wing support
    done afew other mods too
    see how i removed the small 3mm screws that hold the wing bracket and redrilled em larger and basically forced and screwed a steering rod into them
    then made an alloy bracket (saw that from someone elses post afew weeks ago on here)
    then i dod a similar job on the front
    i drilled a hole roughly in the out edges of the front bumper suport and screwed in
    some std pushrods then just bent em abit so the ends are close to the hole in the middle where i put a screw in there
    overall looks pretty spiffy hehehe
    didnt take to make as im rough when it comes to doing this type of work
    i just need to tap the holes in the rear alloy bracket for the pushrod ends
    and make the alloy brakcet bit nicer and clean the edges
    hope it holds
    Aug 2009
    ny
    704
    That looks really nice!! Now go take it off a 20 ft jump and land on your wing or front bumper and tell us how it works! but anyway really nice job and very good idea for the front. I could never figure out how I was gonna do that...
    Thanks,
    Dan
    RC8BE/FLM EMBE/rustler VXL
    Jul 2010
    438
    thanks
    i looked at the rear and then saw some of my pushrods would be correct length if i removed the smaller screws supporting the rear wing bracket so i went for it and it turned out ok
    then tried to see how i can do simialr with front
    Jul 2010
    Sweden
    345
    I've got the rear standard brace mod and it held while landing on the wing. The wing mount broke though and I'd expect yours to break to. The impact force has to travel somewhere and the plastic has been weakened by making holes in it.
    With that said it still is a valid and cheap option as opposed to snapping your bulkheads and chassis so I just might have to copy that front mod and see how it'll perform. Thanks for the inspiration!
    E-Revo Xerun 150A/Leopard 4282//MBX6-Te MMM/CC1518
    Jul 2010
    438
    yer the wings are a weak spot
    my wing acts mroe of a wheelie bar at moment
    its near worn away and one section flaps abit cause its broken heheheh
    S„o Josť dos Campos, S„o Paulo, Brasil.
    98
    Never broke a wing mount - yet!
    I've seen some people making the chassis a bit more rigid by doing something similar to this. They add pushrods between the shock mounts and the rear wing and the same on the front end. Your solution is nice because it seems a bit stronger (nice for bashers); people normally use only 1 pushrod; but it also makes the truck a bit heavier (bad for racers).
    64
    I've only got one in the back, here is what it looks like.
    RC Qualifier oldbikedude's Avatar
    Feb 2009
    Pennsylvania.
    861
    Here is mine. Sorry, me E-REVO is brushed.
    JATO 3.3
    Stampede Build
    DeWalt 12v E-REVO on 4s
