Results 1 to 4 of 4
Thread: Leaking shocks
    401
    Leaking shocks
    so i have Big Bores on my 2wd slash and there always leaking always covered in oil. I was wondering if there was a way to fix this or if its normal and they all leak like that. i run 40wt in fron 60wt out back if it makes a difference.
    thanks.
    Wisconsin
    1,662
    Maybe replace the seals with a rebuild kit.
    Land of the free?
    Springfield, MO
    3,681
    when you say they're covered in oil, it implies they're leaking from the caps.... is that right?
    The bladded inside doubles as a gasket. If you over tighten the caps, it cuts the bladder, and they can leak.
    You just want them snug, no need to over tighten the caps.
    Castle Valley UT and Santa Barbara CA
    706
    They shouldn't leak like that. Maybe you need new seals
    Brushless Summit!!!!!
    Slash 4x4
