Results 1 to 9 of 9
    Wisconsin
    1,662
    Replacing Shock Shafts.. Need help
    Well I bent one of my shock shafts so i'm trying to replace to replace it with the coated ones. What is the best way to go about replacing the shafts? sorry but i'm lost. Also, do you have to replace anything while doing this?
    Thanks in advance.
    Land of the free?
    23
    R the coated ones better than the stock ones?
    Wisconsin
    1,662
    Yep they almost never bend.
    Land of the free?
    23
    Thinking about piggybacks. my buddy has and it sounds like pillow hits over bumps. seem pretty nasty!
    Dec 2001
    Dallas, TX
    681
    Disassembly:
    1. Remove the shocks from the truck.
    2. Remove the ball ends. Use pliers to hold the shaft while turning the ball end.
    3. Remove the caps from the shock and drain the old oil.
    4. Pull the shaft up through the top of the shock.
    5. Remove the e-clip from the top of the shaft.
    6. Remove the shock piston and the second e-clip.
    Reassembly:
    1. Put lower e-clip on new shock shaft.
    2. Install shock piston and top e-clip.
    3. Apply a small amount of shock oil to the threads of new shaft. (To prevent tearing shock seals)
    4. Push new shaft into shock from top.
    5. Install new ball end. Use pliers to hold shaft, being careful not to scratch up new shaft.
    6. Fill shocks with oil.
    7. Tighten shock caps.
    Wisconsin
    1,662
    Ok thanks got them all ready for oil. Will be doing that tommorrow. Is 30, 40, 50, or 60 a better weight for the rear? I'm usinbg the truck for mainly bashing. Thanks for the help.
    Land of the free?
    VICTORVILLE
    48
    im using 35.........is it for a 4x4 or 2wd..........4x4 40-45 2wd 30 35 .................30 is stock oil.
    THE BEST=FAITH IS A RISK
    Wisconsin
    1,662
    Its 2wd. Otherwise I'd be in the 4wd forum.
    Land of the free?
    Feb 2006
    Jeannette,PA
    191
    Now would be a good time to replace x-rings(seals). Rebuild kits are cheap at $2.50 for a pair of shocks.
    Team Greyhound: the 40+ mph club
