Results 1 to 11 of 11
    SoCAL
    32
    Summit with a DX7
    I need to hook up a summit to a DX7, can someone help me with the mixing and setup. Thank you.
    -Mika
    148
    Why do you need to do this? I run planes and cars and it's just no the same. Buy a cheap car remote control off ebay or HK and be fine. My 5 cents.
    SoCAL
    32
    I want to only have to run my rc's using just one remote.
    SoCAL
    32
    I am using a AR7000, I want to do the throttle on elevator and steering on rudder, but there are two servos so I need help on mixing the controller to turn them both. And for the High and Low gear I want it to be on AUX2 or on the gear channel, or even if I can get it on the throttle hold/rudder D/R. Then for the t-lock I want it to be somehow on the flight mode switch, but I need help on mixing the radio
    Thank you.
    SoCAL
    32
    I got everything working properly and I will post the video showing how I set it up. And some driving pictures
    mt.storm wv
    374
    im interested in how this performs...especially after i seen the homemade dig setup thread...
    ???Why so serious???
    JOKER TV
    SoCAL
    32
    Lightbulb
    I am using a Dx7 Helicopter edition (airplane mode)
    Ar7000 receiver with a satellite.
    Channel # - Control - What is being plugged in - Reversed or Normal on TX
    channel 1 - throttle- nothing - Norm
    channel 2 - aileron - slave sterring servo - Norm
    channel 3 - Elevator - Esc - Norm
    channel 4 - Rudder - master sterring servo - Reversed
    channel 5 - Gear - Transmission servo - Norm
    channel 6 - AUX1 - Rear Diff. Lock - Norm
    channel 7 Aux2 - Front Diff. Lock - Reversed
    Wing type
    Flaperon - off
    v-tail - off
    delta - off
    Sub trim
    channel 1 - 0
    channel 2 - 0
    channel 3 - Up - 50
    channel 4 - 0
    channel 5 - 0
    channel 6 - 0
    channel 7 - 0
    Travel Adjustment
    channel 1 - H - 100%
    L -100%
    channel 2 - L - 100%
    R - 100%
    channel 3 - D - 150%
    U - 100%
    channel 4 - L - 125%
    R - 125%
    channel 5 - + - 5%
    - - 100%
    channel 6 - U - 100%
    D - 100%
    channel 7 - + - 150%
    - - 0%
    [ELEV->FLAP MIX]
    ON
    RATE: ->D 0%
    U 0%
    SW:FLAP0
    [AILE->RUDD MIX]
    ON
    RATE: 0%
    SW:ON
    [FLAP SYS.] NORM
    FLAP ELEV
    NORM DN 47% 0
    MID DN 47% 0
    LAND UP 125% 0
    AUTO INH
    [PROG. MIX5]
    RUDD-> AILE ON
    RATE: -100%
    -100%
    SW:ON
    OFFSET: 0
    TRIM
    RUDDER - 5 CLICKS TO THE LEFT
    ELEVATOR - 13 CLICKS DOWN
    SoCAL
    32
    The only problem is when I mixed the sterring together, the master channel will move both servos but the slave channel on aileron moves only one servo as it is a slave. To fix this all you need is a y-connector for the servos and put it on the rudder channel.
    SoCAL
    32
    I have put the receiver and the satellite inside the waterproof casing now. This is a beast now you can now lock the rear diffs. and front diff. separately or together.
    mt.storm wv
    374
    this is a very nice setup for a summit...i definently want one now...thanks for the info
    JOKER TV
    SoCAL
    32
    Quote Originally Posted by afroman123123 View Post
    You can also do dual rates on the aileron channel as I have. you set AILE D/R 1 to zero and AILE D/R 2 to zero so no matter what position the dual rate switch is on you can have no input on the aileron channel.
