Results 1 to 11 of 11
    Billings, Montana
    34
    Tried running two packs in Series...
    And holy cow that's a lot of power. Too much really, at least for the stock tires. Looks like I'll be needing some HPI x pattern tires.
    A warning as well, if you hit stuff at speed, you will probably break the car! I broke the rear axle carrier hitting a mound of snow/ice on the side of the road! At least it's cheap and easy to repair.
    Revo 3.3
    Ken Block Rally VXL
    Associated RC10r5
    60
    I snapped both front and rear carriers on the right side. Installation was easy. but I'm not sure how to do the alignment.
    Billings, Montana
    34
    The accurate way would be to use a set up station for touring cars, but for a basher, it's pobably not really needed. I just eyeball it, and it is usually pretty darn close. I am not going to break out my set up station and tweak board for the rally...lol.
    Revo 3.3
    Ken Block Rally VXL
    Associated RC10r5
    60
    I tried counting turns of the ball screw but it looks way off. is their another way.. maybe with a tape measure.
    7
    I ran two batteries and burned out the ESC and both batteries melted, within 3 runs. I didn't change the pinion.
    Sydney
    Quote Originally Posted by cherrytron View Post
    same thing happened to me but i changed the pinion gear
    west palm beach
    25
    im trying it tmrw with the connector witch has two grounds instead of one witch connecter did you use?
    I also bought some adjustable toe links that are nice and strong. Also when yall broke your knuckles and replaced them what did you put on. i used rpms and have had a ball bering pop out of one but only once
    Any body RC in the south fl area?
    82
    I think every one breaks the rockers doesnt matter how fast or slow you go
    TX
    578
    Quote Originally Posted by tirado_881 View Post
    Rockers or knuckles?
    Rally SV2/4600 and fully loaded
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    Pick up an RPM Monster Camber Gauge it can be used to quickly and easily set bot5h toe in/out and camber . Much more accurate than eyeballing it and easier and cheaper than a set up table.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Delphos, OH
    121
    You will end up using the RPM camber gauge all the time on all your vehicles. I'm shocked how much I use mine
    Revo 3.3
