Results 1 to 16 of 16
    central pa
    310
    series or parallel???
    what are the differences between the to ?? i know that one gives you longer run time(mah) but does the other provide faster speed?
    thanks
    Billings, Montana
    34
    Running your packs in series adds the voltage of the two packs together, which (if your esc can handle it) will result in much more power! Running the packs in parallel, you are doubling the capacity (MAH), and will (about) double the run time.
    Revo 3.3
    Ken Block Rally VXL
    Associated RC10r5
    11,500
    Simple explanation: series means you are putting the + and - end to end and adding the voltage but it stays the same capacity. In parallel you are connecting all the + together and all the - together which will keep the same voltage but raise the capacity.
    For example, put four 1.5 volt, 500mah batteries together in series and you get 6 volts of power and 500mah. Put them in parallel and you get 1.5 volts and 2000mah.
    central pa
    310
    alright got yea
    Sep 2008
    Stockton, Ca.
    928
    [IMG][/IMG]
    Jul 2009
    Ontario, Canada
    11,286
    Great pic right there... very helpful in understanding how it all works. That should be stickied somewhere.
    central pa
    310
    agreed.....
    USA
    3,134
    another thing with running parallel, your amps jump by 2x
    two 2s 2200 30c packs in parallel give you 132amps cont.
    much easier load on the batteries this way, and they will run cooler
    First MiniSlash
    HK6XL Revo 4s 60mph Amsoil dealer
    central pa
    310
    ok thanks.....
    Sep 2008
    Stockton, Ca.
    928
    Forgot I had this also
    FYI Lipo in Series will not be covered by warranty your over voltage
    [IMG][/IMG]
    central pa
    310
    im just running the stock batteries tho no need for lipo's just yet
    Paradise !! Florida
    173
    What speed runs can you get on lipo power ?? Do you think they will come out with a 1/10 scale ?? Will 3s fit with mods ??
    Bullet proof Spart! 4082,180a,m645 niccccee
    central pa
    310
    Quote Originally Posted by yankphan View Post
    x2....What speed runs can you get on lipo power ??
    Jul 2009
    Ontario, Canada
    11,286
    Guys are getting close to 60mph with no mods on one 3S pack. SPC Makes a 3S pack specifically for the mini platform. They fit with no mods and are excellent batteries. If your thinking about going 3S, get those ones. I think theyre like $22 a pack. I have 2 of them and they are amazing.
    Apr 2010
    St. Louis, Missouri
    689
    Not even pinion change?
    Are the tires supposta to blow off going into 2nd?
    central pa
    310
    Quote Originally Posted by M5burndt View Post
    x2..........
