    Feb 2002
    5,262
    mini summit drive axles
    can anyone post close-up pictures of the drive axles? i am curious to see how they are different than the mini revo driveshaft
    i may upgrade to these, or jsut get part 7151x for the merv
    Jun 2010
    Miami, Fl
    6,731
    They are pretty much the same, only diff is the u joint is covered.
    SJ Cali
    115
    Im not sure but the rear arms on the summit are longer than the merv. So im not sure if there is a difference between front and rear drive shaft, longer/shorter?... They are prob the same, just the rears have to extend longer. I would call traxxas support they should be able to tell you if they will fit on the merv.
    Apr 2002
    new york
    1,774
    they are the same length as the merv
    PROJECT BAJA PEDE
    Jun 2010
    Miami, Fl
    6,731
    They are the same lenght. It is just a small diff in the desing, as you can see in the pic.
    Top is the merv, bottom is the summit. The other half shafts are the same lenght.
