    Winter Snow Diff Oil
    Hello everyone!
    Well I just waterproofed my EREB and took it out for a drive through the snow. After a couple of minutes when the oil got up to temp in the diffs, the tires started to unload whenever it was moving less than 5+ MPH. So what diff weight do you use in your diffs? I tried 30 and 50 but I was thinking maybe like 100 or a half and half of 100 and 50?
    I want the tires to not unload so much, but I do not want a spool since those will just twist as I heard.
    So what do you guys run in the snow? Not necessarily on the EREB but in other brushless setups too?
    Grand Rapids, MI
    I'm running 75k front and 60k rear. Get a little unloading, but not bad. Most times all four will spin. My diffs are shimmed up pretty tight as well, so that helps.
    Greendale, WI
    Okay sounds good. Yep my diffs are shimmed nice and tight too so no problems there. I will try 75 all around as last night she was unloading like madd.
    -I am also mmohoney21 (OP) as I recovered my old account now
    Thank you!
