Results 1 to 15 of 15
    Burlington, ON
    132
    Christmas Summit Coming..
    I will be either getting or buying a new Summit for christmas
    i have been reading alot about motors and batteries
    If i upgraded the Titan to a Dewalt 14.4 motor
    can someone recommend (with a link) to some perfect Lipo's to run with it
    that will give the longest runtimes.
    running stock Speed controller.
    727
    Hi,******* lipos are good .The more mah,the longer run time.I get my lipos from hobby king.Try and get the most mah you can afford/will fit in the battery compartments.The summit's a great truck.Toughest truck I've owned
    Jan 2010
    west palm beach, florida
    548
    ******* is what I have atm 5000 mah 30c burst. You can get 4 can't link that site here. or for about the same price you can get 2 spc 8000 mah I can link them I think http://spcracing.com/index.php?productID=61 both great options
    just incase you didn't know you HAVE to use an lva or lvc on the stock esc. Otherwise you will kill the lipos
    Burlington, ON
    132
    can you recommend a charger for them.. that will charge atleast two at a time.
    also how long do they take to charge?
    Lava Land
    341
    Charger Hint (Hyperion) look at wattage , when looking for a charger , get the most watts you can afford and you will be happy done the road . Nice Blue lipos in hard case or Gens Ace ROAR approved (hard case type) google um. BTW no Lipo Cut off on stock ESC , so you'll need to watch it closely (time in steps , check voltage) or get a cutoff or warning device.
    for me i like the NIMH , safe around water . and to me the run time is crazy long already . only thing i did to mine is run a 12th pinion, and put better tires on. but i like crawling around more then blasting full speed . so times are pretty long even on stock 3000 mah . Then again i am use to flying Helis that only give me 15 minute flights . :O
    Have fun with the summit you'll Luv it.
    Victoria B.C Canada
    5,316
    check out the icharger106b+ http://epbuddy.com/index.php?main_pa...&products_id=1
    need a power supply too but this charger does everything well
    Mountains cant stop me
    they have tried
    Burlington, ON
    132
    im confused with Dual Chargers and a single charger with a charging cable that is able to plug in several packs with a parallel connector.
    why would I get a Dual chaarger if i could just get a single charger and a parallel cable.
    if i wanted to charge two lipo's or nimh packs at the same time
    http://epbuddy.com/index.php?main_pa...products_id=83
    Apr 2010
    Northern Michigan
    840
    You can't charge Nimh in series or parallel, only lipos and make sure you do it correctly.
    Victoria B.C Canada
    5,316
    charging nimh is best done separately as the charger doesn't know the state of charge of each cell which could allow some to overcharge and some to under charge.where as with lipo the charger knows what state of charge each cell is at so for nimh i would look at the dual output to help the batt's last longer but I'm by no means a expert i went lipo and I'm not going back i run in the wet all the time i just don't submerge the truck when running lipo.I have some nimh for that but i don't like all the extra maintenance that goes with swimming
    they have tried
    Sep 2010
    685
    Sweet, if my parents don't buy me parts for my emaxx build they will probably get me a summit or flux
    Vxl Slash
    Xerun E-Maxx
    HT Aftershock
    Burlington, ON
    132
    purchased the summit today! it is yellow.. i was hoping for white.. oh well
    i also got a 240 charger and two packs of 5100 Nimh batteries
    cant open until christmas tho
    Lava Land
    341
    Yellow is Great Color, Because I have yellow
    Congrats, ill bet that Tree looks small now , with the big box under it .
    Victoria B.C Canada
    5,316
    The white ones are the fastest from the factory
    they have tried
    Burlington, ON
    132
    DOH!.. i knew it
    Victoria B.C Canada
    5,316
    Quote Originally Posted by adamfilip View Post
    DOH!.. i knew it
    maybe not so good I've replaced my body already
    they have tried
