Page 2 of 2 FirstFirst 12
Results 41 to 63 of 63
  1. #41
    Dallas
    39
    The WB is 206mm width is 185mm. So any body with a WB of 205mm-210mm will work. From what I've seen so far, nothing comes close in width. But some Tamiya mini bodies, and some HPI Cup Racer bodies. Hopfully Proline will come out with something.
  2. #42
    Aug 2010
    Portugal
    241
    will do some research, thank you
    MERV
  3. #43
    15
    Quote Originally Posted by SnoopMaxx View Post
    I think it will be capable of off-road racing, well
    not on the super-cross style 10 Ft jump tracks in the US but on our European tracks that are more like short course tracks with rolling jumps
    And the best part of the Rally VXL is that you can use the Tamiya Rally block tyres and all the cool 1,9" drifter wheels
    Morten
    SnoopMax, do you part number for this wheel/ and drift tires?
    do you have part number for the Datsun?
  4. #44
    15
    How's this ??
    nice body, do you have part/url for this?
  5. #45
    May 2006
    DENMARK
    1,400
    Quote Originally Posted by Manny_E View Post
    I borrowed this photo from pvmacguy Traxxas Forumon
    Morten SnoopMaxx
    3906 ROCKSTAR Makita
    c",)
  6. #46
    central Minne-snow-ta
    444
    OK, I have an extra merv sittin around, and want to do a conversion, I understand I need body mounts, new A-arms, a few tweaks to the shocks, different bumper, wheels/tires, and body. But does any one know the the differential gearing is the same? is the rally runnin a center diff? and what fluid is being run it the diffs? what fluid in the shocks? and I'm guessing that RPM's A-arms for the slash will work right?
  7. #47
    May 2006
    DENMARK
    1,400
    RPM does not make Slash/Rally VXL a-arms
    only E-Revo VXL A-Arms
    However
    If enough ppl ask for them , Then they might make the arms for the Slash and Rally
    Morten SnoopMaxx
    c",)
  8. #48
    Sep 2008
    Stockton, Ca.
    928
    Its the same
  9. #49
    24
    Quote Originally Posted by RobWilJas View Post
    Here's the list I made to convert it from a Slash.
    7335 Front Bumper
    7336 Foam Bumper
    7315 Body Mounts
    7067 Shock Limiters
    7340 Shock Springs
    7372 Wheels/Tires
    ???? Body
    so can anyone confirm this is all you need, i have the m/slash and mini erevo and the merv is all i use as the i find the slash to unpredictable even on 2s. the conversion will save it from being a dust collector on the shelf.
  10. #50
    7
    I have been doing alot if research on this conversion and that is indeed all you need. Also I think heavier shock and diff oils.
  11. #51
    24
    thanks heaps
  12. #52
    7
    The drivetrains are the same? For some reason I thought they were different because when I've been looking for cvds for my slash they seem to make separate ones for the revo and slash
  13. #53
    Jul 2007
    1,322
    They are the same except for the length of the a-arms and drive shafts. The E-Revo and Summit both have the longer a-arms and driveshafts to make the trucks wide. The Slash and Rally both have shorter a-arms and driveshafts to make them narrower.
    I need R/Cers anonymous.
  14. #54
    Jun 2010
    Miami, Fl
    6,731
    Quote Originally Posted by Millertime660 View Post
    not the same the shafst and cvd´s are shorter on slash-rally-KB
  15. #55
    102
    I guess if the merv then a rally can become a merv? Is this possible?
  16. #56
    Jun 2011
    E-Revo conversion to Rally with Tenbol 540 VXL motor
    It's possible and worth it!!
  17. #57
    102
    What is the approximate cost to do this?
  18. #58
    Nastyville Tennisshoe
    341
    I think I said this once befor but I used merv arms with merv shocks and Ken Block or rally push rods and a set 1/10 onroad rally tires that raised it up just a hair higher than the stock rally wheels. this gave the truck the wide stance and only a little more suspention travel than the rally and altho offroad it sucked cause smaller tires and low ride hight it was pretty awesome in dirt like at the baseball field and this one parking lot that has this real fine gravel, I love it, I could go real fast across it and do these cool wide power slides and whips and no flipping!
  19. #59
    341
    [QUOTE=Angrytetsuo;4867010]I think I said this once befor but I used merv arms with merv shocks and Ken Block or rally push rods and a set 1/10 onroad rally tires that raised it up just a hair higher than the stock rally wheels. this gave the truck the wide stance and only a little more suspention travel than the rally and altho offroad it sucked cause smaller tires and low ride hight it was pretty awesome in dirt like at the baseball field and this one parking lot that has this real fine gravel, I love it, I could go real fast across it and do these cool wide power slides and whips and no flipping![/QUO
    And here it is http://s1143.photobucket.com/albums/...TER%20CHASSIS/
  20. #60
    Jul 2010
    Salem, OR
    416
    Quote Originally Posted by FoxhoundEP3 View Post
    i agree with you but if you look closer the name of the car is "RALLY" and all you see in the video is drifting... theres nothing rally about that.... it must be capable of off roading, otherwise "Rally VXL" is not so Rally
    i disagree... being a die hard rally fan for years I understand there are different types of rally car setups. A Corsica Tarmac Rally car is entire different machine than say a rally mexico setup rig. The rally vxl is a tarmac setup and I'm ok with that.
    'Life is for living, not living uptight'
  21. #61
    Jul 2015
    3
    So the rally a arms ,turnbuckles and axles will go right onto the merv....and all ill have to get is dumb stuff
  22. #62
    Jul 2015
    3
    I got the merv b.c it was cheap i want something i can drift or take to the track and i cant do either with this and dont have the money for a rustler vxl or a rally vxl
  23. #63
    RC Racer tmbold's Avatar
    Oct 2014
    Louisiana
    148
    Quote Originally Posted by ibleedblacknred View Post
    and front skid plate
