Results 1 to 2 of 2
    Aug 2009
    Spruce Grove, Alberta
    What if.....Canyon AT's could go fast?
    I just had a thought, and yes it hurt
    Wondering what might happen if the stock Canyon AT's and Geode wheels were assembled with stiffer foams? Not to stiff mind you, but stiffer than the stock foams, and maybe trimmed like this.
    Then again maybe another set of Losi Claw MT's with the foams trimmed like that would crawl as good as the Canyon's?
    What do you guys think?
    Images bigger than 640x480 will be converted into links
    Oct 2008
    the rubber itself is to thin and fragile, they would fall apart the same.
    mabey if u put gorilla duct tape on every square inch of the inside of the tire, but whats the point as that would hurt crawling performance most likely
    T8 sensored/Xerun-150a/custom chassis/fit body
