Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    Jul 2008
    Chino, CA
    378
    Dude, mark the shock shaft with a Shapie at the base of the shock, at the desired ride height. Then just lift the truck, measure how many mm that is and cut a piece of fuel tubing to that length. That way you have an exact measurement of how much to limit them. That's what I did when I was running the Losi 8 shocks and it worked perfectly.
  2. #42
    Apr 2010
    Davenport,Iowa
    851
    Quote Originally Posted by rlopez
    Great idea. But am I right in thinking if I wanted to go back to a higher ride height I would have to remove the tubing?
    Slash 4x4 ultimate MMM 2650
  3. #43
    Jul 2008
    Chino, CA
    378
    Yes.......
  4. #44
    May 2003
    Gering NE
    233
    Quote Originally Posted by rjames
    Or you could unscrew the bottom mount a few threads.
  5. #45
    94
    I was on the losi website trying to figure out which hardware everyone is using to mount the top part of the shocks to the pede? It's not the rebuild kit is it?
  6. #46
    Florida
    360
    Quote Originally Posted by jrjr6565 View Post
    I use the plastic shock spacer in the LOSI Shock rebuild set (Ten T), part # LOSB 2906
    Superman don't need no seatbelt-Ali
    2x SSC SL4x4
  7. #47
    94
    Thanks, I will order that today
  8. #48
    17
    Anybody running the 10-T shocks for just basic running and bashing? I am and they are far better than stock and my crappy Integy shocks. I bought mine on ebay fully built. They came with black medium springs and what I believe is stock 30wt oil. I'm running 35wt in the front now, and 30w in the back. Fronts and backs are set one notch lower on the A-arms. Roll is much better, with wide open throttle runs controllable. Jumps and rough terrain is better too. I still need to mess around with oil weights though. Just wondering what others are running now.
