    Apr 2010
    Abbotsford BC
    476
    rear toe-in? how much and why?
    the one suspension setup item I don't understand is rear toe-in. How much, why, and what does it do to handling?
    is it correct that if I change the PE rear carriers to the "wrong" side it reduces toe-in?
    Ontario, Canada
    1,249
    Quote Originally Posted by Mud Puppy
    Yes they interchange, yes less toe in
    more info here
    http://monster.traxxas.com/showthread.php?t=522995
    Al
    MMM/2650, E-maxx Body=FUN !
    3 Slash 4x4
    Pede 4x4
    92
    Rear toe-in is needed to help keep the rear end from loosing traction on power.
    What will happen if you dont have enough toe in is it will be difficult to keep the car straight and under control on power.
    If you are driving on high traction surfaces, you can experiment with running 2.5 or even 1 deg toe in rear,
    Apr 2010
    Abbotsford BC
    476
    OK, so more toe = more traction under aceleration. What are the disadvantages of more toe then? most of my local tracks have decent traction, and I use the center dif.
    Jun 2005
    Yakima WA
    859
    Lower top speed and an increase in understeer are the tradeoffs for on power stability due to more toe-in.
    Turbo in the front, groceries in the back.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,487
    Quote Originally Posted by turbowop
    Along with shorter life span for the rear tires. The more rear toe in you have the faster you will wear out your rear tires.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Apr 2010
    Abbotsford BC
    476
    I do have an understeer problem, so sounds like flipping the rear carriers might be a good idea.
    Jun 2005
    Yakima WA
    859
    Rear toe isn't the only way to cure understeer.
    Dec 2009
    495
    The rear toe-in is there to be able to control the truck at high speeds, if you had zero toe-in, you would have a real problem trying to drive the truck at high speeds. Look at the Traxxas 4-Tec, Jato 3.3 and other fast vehicles, they all have rear toe-in.
