Results 1 to 16 of 16
Thread: More Rear Steer
    Aug 2009
    Spruce Grove, Alberta
    1,552
    More Rear Steer
    I got rear steering set up on my Summit. A little mix and match of mostly Traxxas parts, Let me know what you guys think.
    Here is a link to a Video.
    http://traxxas.com/forums/showthread.php?536733
    Jan 2007
    regina sask, canada
    2,344
    that looks good
    if your not breaking anything get more air
    SAINT CHARLES, MO
    2,314
    so how does it handle? post a vid of it in action?
    EMAXX-x2,SUMMIT
    RUSTLER VXL
    FERRITE RINGS PM ME!
    Victoria B.C Canada
    5,325
    Are you still running dual up front?
    Mountains cant stop me
    they have tried
    Aug 2009
    1,552
    Quote Originally Posted by jamann
    yes, plugged both front into a y-harness.
    Haven't really tested it outside yet, it has about a 6 foot turning radius though. Gotta get the electrical sealed up, before I get some vid, maybe tomorrow.
    3,230
    Great job , Is your pivot point going through the bumper support (hoop)? Or below it?. I almost have mine up and running but I still have too much "play" in the connections. Im also digging that low stance/ big tire effect.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Aug 2009
    1,552
    Quote Originally Posted by noir522
    Thanks Noir, I used the drill press to make a straight through hole in the E-Revo front bumper mount and mounted a Mini E-revo servo saver inside the hoop. Then mounted the Revo bumper upside down to help protect the tie-rods.
    Apr 2010
    Townsville, Australia
    629
    wow...that looks cool
    be interesting to see how well it goes
    looking forward to the video of it running on the ground
    Aug 2009
    1,552
    Finally got outside with the video camera. I have made a few changes since starting this thread, put a modified front bumper and a summit rear bumper back on, I was going through LED with drawls. I have the springs backed all the way off for this video, my Summit is certainly crawling better than before, but it is a work in progress. here is some video
    http://www.youtube.com/watch?v=J9-VK6k-870
    http://www.youtube.com/watch?v=KARN7wjEEoU
    http://www.youtube.com/watch?v=s-LPeHt02UQ
    Oct 2008
    Minnesota
    541
    Quote Originally Posted by quadiak
    looking good man.
    T8 sensored/Xerun-150a/custom chassis/fit body
    3,230
    very nice build guy, - props.
    Jan 2010
    97
    nice job, build me one and ship it out asap
    6s MMM c_no_summit & c_no_evo_8
    50mph to 150 mph!
    3,230
    the design is so straight forward and with traxxas parts that traxxas should make it stock in the next summit model.
    Feb 2009
    Medway MA
    2,103
    If your summit is a rock crawler why is it so low, making it easier to get hung up on rocks
    Nothin' like a 4 on the floor and a V8
    Aug 2009
    1,552
    Quote Originally Posted by 02hawk
    The simple answer is lower center of gravity(COG)
    I may be wrong in my thinking, but from my rock crawling experiences with my Summit I have found that the softer the suspension is, the more articulation my suspension has and articulation with a low COG is the key to crawling. Sometimes the belly does rub, but it will quite often drag it self over most rocks. That is where the rear steering comes in, to help maneuver around the high center spots.
    Another thing I noticed having the suspension jacked up, is that when the suspension does articulate, it pushes the COG up higher, thus making it tip over a lot more often. I believe the Summit has just as good articulation ability as any crawler out there(other than Super Comp Class), but the true crawlers twist when they articulate where the Summit lifts when it articulates. Lifting is a huge problem, so I am trying to get my chassis to more or less stay put and let the suspension do the moving.
    Most comp crawlers have very little clearance due to the straight axle and/or motor on axle design. I don't think clearance is a big issue when crawling as long as you can either span the gaps with the tires or avoid getting high centered. Crawling is mostly about going slow and finding the best route
    I do however have a plan to increase clearance slightly by going to a bigger tire size, thinking about the RC4wd x-lok lighting super class crawler tire.
    3,230
    quadiak
    you might want to try your system with an Erevo bell crank instead of a merv bell crank, its a little longer (will hang down more) but the extra legth will give the system a wider swing and in turn giving your rear tires a much sharper turning angle.
