    Apr 2010
    So Cal
    32
    Beefing up... need beef...
    What would you guys recommend for a stock Summit - need bigger/stiffer springs and undercarriage upgrades?
    Traxxas Slash 4X4/Traxxas Summit/Losi Mini.
    Sep 2009
    3,165
    Taller/ stiffer tires with heavy rims
    dewalt motor (after the stock motor perish)
    aluminum steering guard
    You probably dont need stiffer springs - just dial up the collar on the shocks and/ or add a higher weight shock oil.
    novak smart stop
    lipo batteries
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Apr 2010
    So Cal
    32
    Ive got the springs dialed up about 1/2 way in the back and 1/3 in the front, maybe a heaver oil. Do you have a link for the aluminum steering guard? Everything underneath is getting pretty beat-up. Thanks btw.
    Aug 2009
    Spruce Grove, Alberta
    1,552
    Quote Originally Posted by Blackie
    when you have the springs cranked up try to keep lube in the CV's, I wore all the ball ends oval where the pins go through and then starting loosing pins. Mine would also squeak alot. I am thinking about trying 100wt on in the shocks and keep the springs set lower.
    http://traxxas.com/forums/showthread.php?536733
    Apr 2010
    So Cal
    32
    Aren't there heavy duty shock replacements?
    Apr 2010
    Townsville, Australia
    629
    Quote Originally Posted by quadiak
    when you have the springs cranked up try to keep lube in the CV's, I wore all the ball ends oval where the pins go through and then starting loosing pins. .
    what do u use to lube them?
    Sep 2009
    3,165
    aluminum steering guard :
    http://cgi.ebay.com/RDLogics-Alum-St...item45eee0dd16
    or something similiar - the only thing really vulnerable under the chassis is the steering arms and servos. You could buy aluminum skid plates but they are not "needed". Besides scratches adds character to a 4x4 rig, and chicks dig scars. The sumiit really is pretty tough out of the box. They wont admit it but the summit/erevo blows the emaxx/tmaxx platform away (especially with their weak/ fragile bulkheads)
    Melbourne, Australia
    80
    get another set of the front (red/orange double stripe) springs for the back shocks, this stops the rear slumping.
    a spare set of bumpers is good to have on hand as the truck is pretty heavy and a bad landing or cartwheel will break them.
    front RPM A-arms are a great upgrade when/if the originals get broke.
    Apr 2010
    So Cal
    32
    Quote Originally Posted by jesterhead
    Thanks jesterhead - Just so I'm clear, put part #5649 spring, shock (red) (long) (GTR) (5.4 rate double orange stripe) (stock front) on the back and this stops the rear end slump?
