Thread: 2.4Ghz Reverse
    Calgary, Alberta
    157
    2.4Ghz Reverse
    I know some of you here have done the conversion to 2.4Ghz instead of buying that way. Have any of you run into the controller taking two pushes of the trigger to get it to go into reverse? Any fix?
    Kinda wishing I stayed with the TQ4... Except for the controller wand that is..
    2.4Ghz Dewalt E-Remmit
    Dec 2009
    Alberta, Canada
    553
    It's the same with the AM. When your going forward and you hit "reverse" it applies the brakes. Then you have to let go and hit reverse again for reverse. My 2.4 does the exact same as the crappy AM system.
    SUMMIT- DeWalt, 4S
    SUMMV- 3S
    MERV- 3S
    Aug 2009
    Spruce Grove, Alberta
    1,552
    but hugh doesn't have brakes!! so it can't work that way
    http://traxxas.com/forums/showthread.php?536733
    Mar 2009
    42
    wish I bought it that way I bought it the day it came out for 499 plus tax got a glitchy am radio (cause i never used the stock motor went straight to mamba monster out of the box)and no batterys. I found a hobby shop 20 miles down the road that says the participate in the power up program so I am going to go see if they have the 2208 high output model on payday spend another 75 and end up making it 575 plus tax and I still do not get batterys I got jacked
    Calgary, Alberta
    157
    Quote Originally Posted by quadiak
    Ha ha, yes, funny guy... What I am talking about, and realize I should have said this in the beginning, is that when the truck is STOPPED, or has been (attempted to) be stopped. It still takes two pushes to reverse.
    I am pretty sure it is the motor, either improper mesh, a blown motor or both that are causing my truck to keep trucking.
    It actually stops awesome if I go fast and turn the wheel quick, that roll cage is great...
    Jan 2010
    Mile High (Colorado)
    212
    Quote Originally Posted by hugh jorgan
    Sounds like you use the same theory my son does with his Slash when stopping. I'll have to be sure and tell him he is not alone!
    Sep 2009
    norfolk,va
    67
    the brake is built in to the esc not the radio and i think its programed in to it because ive used the radio to test other rx's and there is no hesitation on the servo's when i use them.
    Calgary, Alberta
    157
    As a final update on this. After going through the entire factory set-up procedure on the controller and ESC, this problem has now vanished.
    I basically started at step 1 and went right to the end, being careful not to miss any thing in between. NOW I am liking the 2.4Ghz
    Jan 2008
    USA
    1,507
    Quote Originally Posted by Faultor
    Just so you know, the high output radio is only two channels, although the receiver will be sufficient.
