Page 5 of 5 FirstFirst ... 345
Results 161 to 191 of 191
  1. #161
    1,823
    Post 19 shows the mod. A good caliper to measure the ID of a pipe and the area the pipe will go and possibly a drill bit, add that to boiling and it’s a fairly cheap mod.
    Cads, Insane RC, PWC,and BOAT CORNUCOPIA
  2. #162
    261
    Dont need a pipe tube.. Just take the rings off the stock knuckles, and press them on the RPM`s.. Fits like a glove, and probably is ment to be this way..
    The boiling part might work after it starts popping out.. I know plastic often gets it`s molded shape back after boiling it, if it gets too cool of slowly again..
  3. #163
    1,823
    Didn't think about the stock PE steel part fitting on there.
  4. #164
    Feb 2008
    790
    Guys, I do use the stock steel rings on the rpms that I use in the rear ..... Look at the pics I posted while I installed them among with the Lst drivetrain.
    I have been thinking of using them in the fron too, I might do it when I run out of spare stockers...
    Ola, I have every single part I need except a new reciever..... They didn“t show up before the weekend.. so no driving..But thats pretty okay, I will be at work 24/7 anyway until wednessday
    Ola, have you ever tried to order parts from dollarhobbyz at ebay instead of towerhobbies? I used to shop all my spares at tower before, but every package got stuck in the toll and the delivery time was slow.
    When ordering from dollarhobbyz They ship it as a gift so you don“t have to pay toll, and I always have my parts delivered within a week from them. They just have stockparts tho... For the flux and the revo .
    I strongly recommend them
  5. #165
    261
    Thanks for the tip!
    I use Jenny`s alot, but they are mostly auctions and not buy now`s..
    I actually bought a 1515 2200kv from them yesterday.. I think the 1717`s gotta go on the shelf for a while To heavy, and makes just more problems than joy right now.
    Ill check up on dollarhobby`z next time i need spares! Tollfree is one of my favourite words lol
  6. #166
    Feb 2008
    790
    Well, It happend. I have a new project:
    You can read about it here: http://www.rc-monster.com/forum/showthread.php?t=29831
    It has some revo parts like the gearbox and such but I doubt Traxxas would let me post it here anyway
    Happy Bashing everyone!
  7. #167
    338
    Quote Originally Posted by Manne View Post
    Beefy beefy beeefyy:
    And this is the end station:
    Can“t wait to get my hands on some Lst cvd“s, the summit shafts will have to do it for now.
    What center cup did you use for the LST diffs?
    Well just went on reading your post and found out that its the savage 8mm cup, could you please be more specific???? i mean which savage uses an 8mm cup and where, or it would be great if you post the part number.
    Thank you.
    Last edited by uninterrc; 06-03-2011 at 06:43 PM. Reason: Continued reading the post and found out the answer to my question
    SUPERMAXX, ERBE, T-MAXX, MERV
    SAVAGE &TROPHY FLUX
  8. #168
    338
    So, Update.
    I“ve got the stuff! I will make this long story as short as possible, if there is something that someone is wondering, feel free to ask.
    I decided to use the Stock outputs that comes with the Lst diffs, If you install everything like Mc did the driveshafts will be too short for my likening since the outputs will sit longer in on the diffs than if you have the stub axel mod with additional cups on for the cvds, To fix that I simply used a additional layer of bearings in each knuckle, A easier way to do it would be to use Tekno carriers, I will try that version later on.
    I used:
    Alot of 8mm shims.
    4 Lst cvds.
    2 lst differentials.
    1 rear dogbone, savage.
    1 drivecup, savage with 8mm bore.
    1 drivecup, savage with 6mm bore.
    2 grub screws from the center lst-cvd that came with the diffs.
    1 drive cup ( or what to call it ) from the center lst-cvd that came with the diffs.
    1 complete summit shaft with two diff output axels on it.
    4 15x24 bearings for the rear rpm knuckles.
    4 8x16 bearings for the rear rpm knuckles and front stock knuckles.
    4 15x21 bearings for the front knuckles.
    This is how I did:
    I started to install the metallrings I had laying around from some stock knuckles on the rpm knuckles, it“s a good fit.
    Then I enlarged the outer hole on the rpm knuckle to make the 8x16 bearing fit.
    I took two of the four 15x24 bearings and put a layer of thin tape around them, the outer hole on the rpm bearing is about 24.8 so the fit is a bit loose without the tape, some 25x25 bearings would be perfect but I couldn“t find any...
    And then it“s ready for the cvd install:
    In the front I just removed a little bit material from the seats for the 15x21 bearings to make it easier to press in the bearings and get them out later on if they breake, I removed a very tiny bit of material with a knife. I used dual 15x21 bearings in each knuckle to make the shafts go really really deep into the drive cups when using LT rockers with P3 pushrods for that super high ground clearence. No binding have occoured.
    The cvd“s have about 0.2mm of play from bottoming out in the drive cup when the suspension is compressed, but I like it that way, no cvd“s is popping out on my truck.
    you said you have inserted 2 15x24 bearings into the outer hole of the rpm knuckle which is about 24.8, so whats the diameter and width of the inner hall. and what about the width of the 15x24x? bearings?
    SAVAGE &TROPHY FLUX
  9. #169
    338
    So, Update.
    I used:
    Alot of 8mm shims.
    4 Lst cvds.
    This is how I did:
    so the 8x16 bearing is a direct fit to the stock front knuckle?
    SAVAGE &TROPHY FLUX
  10. #170
    338
    Got another question for you....you see i am making my last order and i want to make sure that i dont miss something out when i convert to the LST diffs and shafts.
    I would like to know your suggestion on gearing with the LST diffs, i am sure the ratio changes so could you give me some examples of the ratios i could use?
    SAVAGE &TROPHY FLUX
  11. #171
    207
    sikk man, are those paddles the proline maxx paddles? and can you use them with the erevo stock rims?
    Traxxas and yamaha - cant do anything without them
  12. #172
    338
    sorry for bringing this back up but i need to get an answer for my questions.
    Manne where are you?????
    SAVAGE &TROPHY FLUX
  13. #173
    Beeville Texas
    230
    out making some vid???????????? i hope, love this thread
    my summit suxs
  14. #174
    Jul 2010
    Sweden
    345
    IIRC both Manne and Ola has moved on to other brands and projects.
    Sent from my Desire HD using Tapatalk
    E-Revo Xerun 150A/Leopard 4282//MBX6-Te MMM/CC1518
  15. #175
    338
    too bad.....so they dont even bother having a look at the traxxas forums?
    SAVAGE &TROPHY FLUX
  16. #176
    261
    Quote Originally Posted by uninterrc View Post
    Rarely
    For stock knuckles, you use 2x of 15x21mm bearings on the inside, and 1x of 8x16mm on the outer side. Inside fit perfect, the outer bearing is larger than stock bearing, so the knuckle needs some work done.
    For RPM knuckles, same outer side bearing/issue as above, but 2x of 15x24mm bearings on the inside. This is when you need a layer of tape around them, to fill the 24.8mm hole in the knuckle.
  17. #177
    Feb 2008
    790
    Hello!
    Long time no see. I“m so sorry, I used too look here now and then to answer questions but no one wrote anything in a long while and then I trusted the " e mail notification"....Shouldnt have done that... Anyway, if you still are wondering
    *Yes it“s maxx paddles.
    *The 8mm cups are: Hpi 86083.
    *Good that you are here Ola when I can“t show up Jusy a little correction, If you use rpm knuckles the 8x16 bearing on the outside is a DIRECT fit and needs no work on the outside.
    *I used the rear centershaft from a savage flux, part number HPI 86056.
    *Gear it for a bit more speed then you had before the diff swap, go up one or two tooths on the pinion.
    I Moved over the electronics, gearbox, wheels and tires etc to the flux the last time I Broke It and then finished the flux build instead of fixing the revo, Haven“t looked at it since, until a few days ago, I started to miss it, so I took it to the work bench and started wrenching
    When I get payed I think I will order the following to get the truck running again:
    Complete gearbox
    6mm outputs to the gearbox
    Mamba Monster
    RD racing Servosaver mount
    RD racing knuckles all around
    Aluminum full skid "non cut" for the front bulkhead
    Recieverbox
    Savage headprotector
    Some bearings
    Wheels and tires.
    The plan is to get the revo up and running as a second truck a bit race inspired.
    I will get some really light wheels and tires and adjust it to have good handling instead of having 40inches of ground clearence.
    I“m thinking badlands, does anyone have a better suggestion?
  18. #178
    1,823
    I am loving my trenchers on my converted revo.
  19. #179
    Feb 2008
    790
    Sounds good! But aren't they a bit on the heavy side?
    The truck have sucesspfully ran thre packs today!
  20. #180
    Sćo José dos Campos, Sćo Paulo, Brasil.
    98
    You are probably right!
    You should try Traxxas Response Pro + Dish wheel or maybe Pro-Line VTR 4" rims with a VTR tire such as: Caliber, Hole Shot or Revolver. IMHO I prefer the Response Pro + Dish because it is wider (83mm) than Pro-Line wheels (60mm) and that improves handling quite well and the Trx wheel has a (very) little offset too. It is quite hard to find wide offset rims these days…
    I have a Badlands for bashing and I never understood why using this - it doesn't give that much traction under loose dirt so maybe it's better to use a race tire for bashing or any other (it certainly look cool but that is not what I want - I want traction!).
    The only concern I have about race tire is that they tend to be less strong against rocks and they get torn\cut more easily than any other type of tire - so stay out of the throttle on rocks or you may torn\cut your tire.
    It would be better to use a "pillow" tire such as Terra Pin or any other for bashing. I do not like 40’s series tires because they are huge but they also weight twice as a racing tire so stay out of it.
    I just got HPI Dirt Bonz race tire and I’m looking for a nice offset rim for it (it must be light weight as it is for racing). If any of you guys know one, please tell me!
    Strive not to be nitro, but rather to be electric.
  21. #181
    Feb 2008
    790
    Thanks for your tips and your opinion!
    At the moment I“m using Hpi Gt2 tires ( stock flux tires ) on pro-line 1/2 offset 23mm standard "maxx" sized dish wheels wich are really hard to get to sweden these days for a decent price..But they are the only wheels that will hold up more then 30minutes of my kind of driving.
    I like the vtr“s, but I“m kinda stuck on 23mm, so maybe I“ll go with crime fighters ( I“ve used them before once ) but they tend to wear so wicked fast even when I don“t drive on asphalt, but thats life with brushless insanity I guess.
    If anyone know about some rims with 23mm hexes, please shoow me them, except the 40 series...
  22. #182
    1,823
    Threnchers are a bit heavy I don't remember what they weigh off the top of my head.
  23. #183
    Feb 2008
    790
    Long long time and no see. But now, we are back.
    So what have happend in the time that we were gone?
    I got the Savy, and the Revo collected dust for a while, but then, it turned Summit with locked Lst diffs etc.
    But I got tired of the speed after a few runs so then it went slayer, that later turned into something IdontknowbutIlikeit:
    E-slayer:
    E-something nice:
    And now my flux has been stolen, so the Erbe will now come back to life again in it“s true form! Ordered stuff for 350$ this evening so the rebuild will begin soon! I“m glad to be back. Really missed this truck.
  24. #184
    Feb 2008
    790
    This is how he sits right now:
    To be continued.......
  25. #185
    Feb 2008
    790
    So, time for an update!
    Have been driving the truck for about 10charges now, and believe it or not, nothing major have broken!
    The setup is the following:
    Stock esc and motor
    Lst diffs
    Lst driveshafts
    Savage center axels
    Hpi Gt2“s on some random 17mm dishwheels.
    Got some new 5s lipos for it aswell.
    Using some homebuilt bracing front and rear:
    Widned the battery compartments for the fat 5s“s to fit:
    Bought a fan kit for the motor:
    And here is the beatup complete truck
    Thats all for now! Happy bashing
  26. #186
    Feb 2008
    790
    Forgot to mention that I bought a sidewinder 8th combo first for it, lovely esc, until it smoked.
    The amps got a bit high on 5s, geared for 60mph without the baloning added to the equation...
    I think that esc would work great with proper gearing. After the meltdown I bought the MMM again
    Unfortunatly when the esc burnt the receiever went along with it... So I went up on the attic and there is was! Back to the oldschool style
    But I simply couldnt stand it, all the glitching and studdring... So today the mailman came with a cheepo Hpi remote and receiever. As usual Castle were very kind and replaced my sidewinder for free! Yaay!
  27. #187
    Jun 2014
    Lousiana
    342
    u should put a wing on it it would look SICK!!
    Don't force it out. GET A BIGGER HAMMER!!
  28. #188
    Feb 2008
    790
    Time for an update again!
    Empty wallet: Yeah, I really really like the look with a wing, but It just don“t fit my drivingstyle. I hade a period on my old Erbe when i tried to have a wing...One chassi, five wingmounts, and five bodymounts later I decided to ditch the wing.....
    Had some good weather in the bashing spot lately:
    Wich made my mood to go trough the roof and buy a new body for it in happiness (ford f650, I really disslike the fit, but that was what the lhs had in stock atm):
    And I decided to change the lower rear arms for some stockers, due to the rpm arms flexing way to much and constantly bending the driveshafts. Also changed to Traxxas p3 pushrods in the rear to get some more groundclearence:
    And that is all for now
  29. #189
    Aug 2014
    5
    That looks thight!
    What kind op plasti dip did you use, the brush on stuff, or a spray can, or than bucket where you really have to dip it in?
    Great build!
    Update:
    The new esc is finally here!
    It runs smoother than my mamba max in some wierd way It“s really really easy to program with the programcard, and after about 7hours of use, I“m still very happy with it! I turned the fan in it upside down so the air will be pushed away from the esc to make the snow blow away instead of getting sucked in to the esc.
    Some before and after pics of the plastidipping:
    Before:
    And after:
  30. #190
    Washington,DC
    45
    Have you tried Corrosion X ??
    I've got it on my Mamba Monster and its been protecting it for the past 3 years now.
    Have to reapply every 6-8 months or whenever I do a tear down.
  31. #191
    Feb 2008
    790
    Long time no see again!
    A friend of mine have been "renting" the Erbe for about a year now, this is how he“s experience have been with it:
    It will now come back from the "renting" and will now once again be turned into something slash/pede looking which you can follow here: https://traxxas.com/forums/showthrea...ayer-pro-build
    It will take some time before I will be able to complete it tho.
    Happy bashing everyone!
