Results 1 to 2 of 2
    Feb 2009
    57
    MMM - Parts to acquire
    Other than acquiring the MMM motor and ESC, which pinions ans Spurs should be used ....
    Mod1, 0.8 or 32P ?
    I know you need 5mm bore for the pinion.
    Which Spur ?
    Which Spurs ?
    How is the stock motor mount plate holding up to MMM or should I immediately order the aluminum mounting plate ?
    What about the lower mount ? Leave the stock plastic or go aluminum ?
    Sep 2008
    NewYork
    673
    stock spurs are fine , as for pinions an 18t , 20t , 22t and 14t should be fine , really depends on what batterys your running , also a traxxas battery expansion should be good and the traxxas erevo esc mounting plate , and a stampede waterproof receiver box. Stock mounting plate is holding up fine but an optional one should be out soon. Is the new one out? Oh and 32p pinions 5mm....
