Results 1 to 22 of 22
    Aug 2009
    7
    How to make Revo wheelie?
    Anyone can help me,my Revo 3.3(5308),after break-in engine,everything is good.But each time I want to step/climb up to pedestrian ,only the front wheel can,then the engine shut off!
    I think my needle setting may not correct?
    Anyway,I want to wheelies,but it cannot to do!
    The high speed needle may be need to lean more ? Make the engine more power ? The rear supsension seems to be too soft ,need to harden ?
    Any setting need to change? I only use the stock setting!
    Dec 2008
    Mission, TX
    166
    Your tune is off, most likely the low speed needle or idle. Follow the tuning tips... get a temp gun too, that helps out a lot when tuning.
    http://monster.traxxas.com/showthread.php?t=334452
    Revo might not wheelie so much because of the suspension setup. Stiffer springs will help. I personally don't like wheelies but my Revo 3.3 will if I gun it from a stop.
    Aug 2009
    7
    Quote Originally Posted by mx2004
    Thanks your fast reply
    I use the pinch test ,LSN seems to lean
    I will keep trying,thk a lot!
    Jan 2005
    Southwest Louisiana
    2,263
    My 5309 wheelies on demand right after break-in, your tune must be off.
    Thats a bumper? I thought it was a wheelie bar!
    Aug 2009
    19
    1+ your tune is off and i just got my brand new old 5308 and mine will do wheelies but after awhile it gets old
    Aug 2009
    9
    i took out the front drive shaft and mine wheelie all the time but it handaled BAD
    yes i just did that
    356
    You can always put in thicker shock oil and stiffer springs in the rear, that would help. But a good tune is essential.
    What are these "brakes" you speak of?
    Jan 2008
    Sugar Hill Ga.
    8,397
    Quote Originally Posted by laboheme01
    You need to Tune the engine before you worry about wheelies...
    Feb 2009
    577
    and BTW the revo is a RACEING truck, it is made to have all 4 wheels on the ground, so doing wheelies will be harder. i like my 4 wheels planted on the ground.
    Jul 2006
    Derbyshire, UK
    447
    Question is how not to wheelie.....
    OS18TM, original 2.5 Revo, lightened = wheelies on demand, sometimes when it changes to 2nd as well.
    REVO 2.5R
    OS .18TM Carbon Fiber Edition
    Feb 2009
    577
    i KNOW THAT i just do not know why people get the revo and try to get it to wheelie when you can get an t-maxx that is made for that stuff
    Aug 2009
    7
    Quote Originally Posted by REVOKID123
    why I want to wheelie?
    Because I find if my needle setting is right,the truck sould be powerful to be wheelie,I only want to prove the engine is in right tuning,
    In website I have seen Rev can wheelie,so I want to do so!
    Jun 2008
    Port Elizabeth, South-Africa
    4,562
    get close ratio internal gearing with 14/40 clutch spur combo and tighten the slipper clutch until it wheelies... 14/40 is the most punch you can get with the Revo...
    If you don't like Nitro, you don't like anything!
    Feb 2007
    Nor-Cal
    1,143
    You have a great point. A wheelie is a great indicator that you are getting your tune in the ballpark.
    _
    /_/._ _ _
    / //_ /_ /_/
    Feb 2007
    Nor-Cal
    1,143
    Quote Originally Posted by Switch_639
    You are right about the 14/40, but you don't necessarily need the close ratio gear set, as all of the 1st gears are the same ratio. The close ratio gear set might make the wheels pop off the ground when it shifts into second if you have a perfect tune, and your shift point set a little later.
    _
    /_/._ _ _
    / //_ /_ /_/
    Jul 2006
    Derbyshire, UK
    447
    As soon as we get better weather here in the UK I will take some vid of my Revo pointing skywards. If you are not a racer it is cool to set of and give it some wheelies. After all it about having fun with your truck - I love it and that is why I have the wing and wheelie bar.
    REVO 2.5R
    Jun 2009
    350
    get the rig moving oh 4-5 mph then let out of the gas but don't brake. let the engine unspool then floor it. works every time. its easier to get moving if its already moving
    Use your Keyboard, OMG sounds Girly
    Jul 2006
    Derbyshire, UK
    447
    Here we are, my short wheelie vid......
    Revo wheelie video
    REVO 2.5R
    Apr 2002
    glenwood iowa
    165
    properly tuned it should wheely all day long. go back to factory settings and then retune, tighten slipper if thats loose it will not wheely. my stock 3.3 will wheely nicely, and my full modded 3.3 wheelys like crazy. had to put center dif in to keep front down. anyway retune and check slipper then shocks etc.
    its only money
    May 2006
    Sacramento CA
    158
    The first vid is of my 3.3 and the other one is after the bb conversion. Even with 3.3, when properly tuned will wheelie all day long. Now with the .28 it's a different story. Thinking about tying a brick to the front bumper to keep it down lol.
    http://www.youtube.com/watch?v=jLlZVVJML4c
    http://www.youtube.com/watch?v=UpTk9t85Epw
    Revo.28 http://www.youtube.com/watch?v=Dscu3-a3DX0
    Feb 2009
    577
    get good fuel, like BYRON'S
    Feb 2009
    in my man cave
    269
    sweet vid's david
