Results 1 to 13 of 13
    Apr 2009
    25
    Exclamation solved my hot problem
    I live in south Louisiana and everyone knows that we have heat and humidity.
    My e-revo and slash was runing hot with the stock battery since I received it about two weeks ago, but not to the point of the heat shutting it down. I did some looking on the net and decided to put a opening in the "windows" and an opening in the "windshield". I now have Max Amps 1600 batteries and ran the two batteries back to back. The temp of the ecs and motor was noted to be very cooloer that just running one of the stock batteries before I did the body mod. I already had a heat sink on back order, but now I am not shure if I will need it.
    One other note: All I can say is "WOW!" The difference between the stock traxxas battery and the MaxAmps is unbelievable. Now do not get me wrong, I like the Traxxas batteries, but the output difference is very noticable.
    May 2007
    318
    yes use the heat sink to! I have the hole in the window and a heat sink and the temps are in total control !
    "You must first climb, to be at the top"
    May 2009
    153
    I'm also in South Louisiana, right outside Baton Rouge
    Also switched to the MaxAmps, and it made a HUGE difference.
    May 2009
    Phoenix
    116
    Yup some people complain Maxamps are pricy, but I had several for my other minis, the maxamps battery kicking axx... on top of that, other lipo I own bluff a little once a while. Maxamps' sitting there solid, and some of them I have them over 2 years now. Definitely worth the price if you ask me.
    Quote Originally Posted by emsemt911
    Some people buy the window screen "net" and fill in the windshield to prevent rock, dirt, or bugs got it. You might want to try that too, works well.
    RC Champion TMaxxcrazy33's Avatar
    Dec 2008
    Va
    1,668
    my mini revo is geting hot...so what is the body mod is emsemt911 talking about
    slash
    summit
    rampage mt
    tmaxx
    SCX10Dingokit
    May 2009
    153
    Just cutting a hole or cutting out the front and rear windshields altogether.
    Then go to a place that sells window screen material, or a place that will give you some scraps and glue it in the windows to keep debris out.
    That $5 or so heatsink from Duratrax helps to.
    Jun 2009
    798
    Quote Originally Posted by TMaxxcrazy33
    he just cut a whole in it..........its not really a mod this is a cooling mod
    http://www.rcbros.com/forum/forum_po...?TID=6691&PN=1
    keep your mouth closed and let your eyes listen
    Dec 2008
    Va
    1,668
    thanks man
    slash
    summit
    rampage mt
    tmaxx
    SCX10Dingokit
    Jun 2009
    798
    np .
    May 2009
    Phoenix
    116
    Like this TMaxxcrazy33,
    http://monster.traxxas.com/showthrea...=window+screen
    Just to increase air flow throught the body. If you go Home Depot or Lowes' they have more than a dozen different types, colors, thickness to pick from.
    Dec 2008
    Va
    1,668
    if i get a other battery and just leave the stock pinion on the motor or will it mess up somthing
    slash
    summit
    rampage mt
    tmaxx
    SCX10Dingokit
    Jun 2009
    798
    itll work perfect like that
    Dec 2008
    Va
    1,668
    iight thanks man
    slash
    summit
    rampage mt
    tmaxx
    SCX10Dingokit
