Results 1 to 8 of 8
    Mar 2006
    Canada, Québec
    606
    charging time with stock charger ?
    How many mah the wall charger have for evaluate the charging time
    thank
    Stampede 4x4 1415 1Y 2400kv, 4S 5200 30C
    USA
    3,134
    The stock wall charger has an output of 9v at 200mA
    Jun 2008
    333
    well if they are 1600mah..
    charging at 200ma will take about 8 hours :O!!
    USA
    3,134
    the stock battery will take about 6hrs
    denmark/værløse
    25
    i'm glad i've have 2 duratrax ICE chargers
    1:16 e-revo VXL is on the way to me
    May 2009
    Southeast PA
    1,928
    You have to put in 150% of what you took out to recharge a NiMH pack back to full capacity. Lipos you basically put back in what you took out. The stock charger is not a fast charger! It is a very conservative charge rate which will make the batteries last a lot longer. You should go easy on your packs for the first 6 to 10 charges if you want them to last. Charging FAST at 1C requires a good peak detection charger and even better one with a temp probe. FAST=1C, MODERATE=1/10C, SLOW (trickle)=1/40C.
    Native Floridian
    257
    I hope you are talking about Ni-Mh batteries, because you should never trickle charge a Lipo, unless one cell went south on you below 3.0 volts, then it is trickle time to 3.2 volts per cell then back to 1C charging.
    TEKIN RX8, BANTAM BC8DX, MAXAMPS!!!
    May 2009
    Southeast PA
    1,928
    YES ...We are talking NiMH batteries.
