Results 1 to 30 of 30
    May 2009
    World's Largest Archipelago
    1,173
    Brushless equivalent of the Trx Titan 550 12T?
    Hi,
    Since there are many debates concerning which BL esc to go or what kVs to choose..I'm probably the only person here that thinks the Titan 550 12T motor is kinda..well adequate. At least for the moment.
    Anyway I want to have a maintenance free BL motor, which is similar or slightly better in performance to the stock brushed Titan. Can anybody recommend the turn numbers or the kV rating?
    Oh one more thing...does a lower kV / higher turn always means a bigger torque? say a 4000kV to a 2000kV?
    Thanks.
    Jun 2007
    NOT HERE ANY LONGER
    1,852
    I'm not sure what brushless motor would be equal to the Titan but I know that they are out there. Look at the Novak systems if you are sure that is the way you want to go. Personally I'd buy a VXL system and run it in training mode until you feel the need for more power. The need will hit you very quick
    As far as motors go. Assuming you are talking about the same make. Yes the Lower the KV the more torque it will make. A good 3000 to 4000 KV motor works great in a Slash. You don't want to go much over 4000.
    Sep 2004
    nj
    1,100
    Quote Originally Posted by Out of Sight
    Hi,
    Thanks.
    Hi A 3300KV @ 7.2V should be close to the titan 12. that's 23,76RPM @ 7.2V the titan 12 is 22,000 to 23,00RPM
    So some whare in 6the 3100KV to 35000KV should be good.
    Thanks
    Z....
    Mar 2009
    Tucson, AZ
    255
    John01574 has it right. I got the vxl and did the training mode until I wanted more speed. VXL in training mode is about equal to titan 12t.
    free track. need tucson racers. PM me
    May 2009
    1,173
    thanks guys. Other reason why I'm looking for a similarly performanced BL system is because I'm still running a 7 cell Nimh- 8.4v 4000mah. I get around 20-25 minutes on the Titans. I was hoping the increase efficiency of the BL will see more run time. Although I have 3 packs...which see continuous run of about an hour on a Titan.
    I probably get the VXL or the cheap EZrun,..until I get my hand on a Maxamp Lipo, i'll just stick to lower kv motor. These lipos cost as much as the truck!!
    May 2009
    1,173
    Quote Originally Posted by SWEETZ28
    I'm having a hard time looking for a Titan's spec...any links?
    Sep 2008
    Bonnie Scotland
    643
    I managed to find this
    "Xtreme RC Mag Dyno results.
    Motor Data
    Battery pack used: Reedy X-Rater 3700 6cell Stick pack
    Motor: Traxxas Titan 12t 550
    Wind: 12-Single
    Max Power*: 40.24W @ 7,772rpm
    Max Torque*: 72.16 Nmm
    Peak RPM*: 14,599rpm @ 2.6sec
    Efficieny*: 52% @ 11,358
    Motor Settings
    Timing: Fixed
    Brushes: Internal
    Springs: Internal
    Acceleration (0-60FT): 3.09sec @ 26.0mph
    Top Speed: 30.9 @ 210ft
    Average Run Time: 6+mins
    Gearing
    26/76"
    A motor of 3000kv will be a good replacement motor
    A lot more torque in acceleration, similar to better run time and similar top speed
    I was born to break the mould
    Sep 2004
    nj
    1,100
    Hi i have a RPM checker and it was like 22,000 RPM @7.2V i recall
    Thanks
    Z....
    Jan 2002
    Northern Virginia, USA
    135
    Quote Originally Posted by Hardcoretam
    Motor Data
    Wind: 12-Single
    Motor Settings
    Timing: Fixed
    Brushes: Internal
    Springs: Internal
    Gearing
    26/76"
    Only 40 watts? A nice stock motor Has like 120 watts. Weird...
    -Stregone
    May 2009
    1,173
    Motor Data
    Wind: 12-Single
    Motor Settings
    Timing: Fixed
    Brushes: Internal
    Springs: Internal
    Gearing
    26/76"
    Gee..thanks man. This is what I need! Yes, it's a good thing u mentioned about torque..that's exactly what I need. I mostly bash at my backyard, where there's only 50 feet of straight the rest is some tight twistys. I already installed a 16/90 gear combo, it helps "move" the truck around. Although looking at the specs...that's a good healthy torque from the Titan. 72 Newton Millimeter..or about 720 grams/cm. Tamiya Super Stock 540 TZ only makes around 400 grams/cm.
    How much torque does a 3000kv motor or 3500kv Velineon makes? Just wondering...
    I have an old tamiya buggy chassis, with a brand new stock 27 turn silver can johnson motor, it has a more responsive "hole shot" acceleration out of corners. But that's probably due to a much lighter weight of the Tamiya.
    May 2009
    1,173
    Quote Originally Posted by Stregone
    It's probably "at the wheel" power, ie chassis dyno, just like in a real car..not a direct result taken from the motor shaft. Wheel horsepower is significantly lower than actual power the motor is making due to friction loss, tire size and gear combination in the transmission.
    Sep 2008
    Was there, now here.
    2,434
    Once you go brushless, the whole world changes because a good BL system can theoretically make unlimited torque. This depends on how much amperage the batteries can supply, and how much heat the system can handle, of course.
    RustyVXL, HPI RS4 Rally, RC18MT
    Mobius1 crashed!
    Apr 2009
    Bay Area, CA
    924
    I never ran my Titan 12T and went straight to the VXL. I love it! It's plenty fast and has plenty of torque. If I need more power I'll just take the 2S out and go 3S.
    May 2009
    1,173
    Quote Originally Posted by BigART71
    Yeep...that's what I'm saving up for at the moment. But the LVC cutoff issues on the VXL kinda throw me off..do you suffer any issues with it? I really dont want to buy something that I might regret later, I'm a man on a mission and a BUDGET! I'm saving up also for a good Lipo..most likely those of Maxamp.
    Myth busted: Blitz is not faster on the track.
    Apr 2009
    Bay Area, CA
    924
    I haven't and the LVC issue at all.
    Tower Hobbies has the Castle Creations Sidewinder on sale right now. If I get another Slash I was thinking of getting the 4600KV setup. It's slightly less expensive then the VXL so far that I've senn.
    May 2006
    Utah
    538
    I'd have to say the Titan is about equivalent to somewhere between a 17.5 and 21.5 turn Novak motor, if you are using that scale. I ran a fairly nice 27 turn brushed stock motor and found the performance pretty similar to the Titan.
    May 2009
    stl, missouri
    127
    i race my cars, so i really need a system that is close to the titan (the track we have is tight, and does not have much traction)
    any good suggestions
    Dec 2009
    New Hampshire
    589
    I have a 10.5T novak ballistic, and honestly, I expected a bit more from it. It has more power than the titan (I am using the same 7cell 3000mAh battery as when I had my titan), but not much more speed (at least at my generous 12:56 gearing)
    I got maybe 5mph more top end out of it, but the thing has amazing torque and low-end. I don't do wheelies, the wheels just spin.
    It is also very controllable at low speeds, and has never gotten over 140 degrees F, and rarely ever goes above 120.
    I also like the programability of the novak ESC over the straight plug and go(ish) of the vxl. I have mine tuned just the way I like it, with all the fun extras. It makes it handle just that much better.
    I am satisfied with this motor, and really wouldn't need anything more.
    another + is that it is easily taken apart and cleaned, and you can replace individual components.
    I could imagine the ballistic 13.5T being pretty close to the titan.
    I am lucky I don't have any money.
    Jul 2008
    Michigan
    1,319
    about 2800kv or so
    Yes, I drive an electric converted Nitro Hawk.
    32
    So you are saying a 3000 kv motor has more torque than a 4000 kv?
    425
    Yes and don't get a Maxamps lipo
    KNEE INJURIES HURT !!!
    161
    Be careful if you intend to buy an ezRun as there are a lot of counterfeit versions being sold at the moment.
    There's discussion about this on another forum that I frequent and Hobbywing are trying to stop it.
    As has already been suggested, another good alternative is the Sidewinder SCT. It's worth the money just for the powerhouse of a motor.
    Quote Originally Posted by Out of Sight View Post
    Sent from my E10i using Tapatalk
    Jan 2008
    South Jersey
    8,407
    I was racing my Slash at an indoor track over the winter and they combined the "spec" class and "17.5" class a couple times. There was little to no performance difference as far as motors go. Then again it all depends on how well you can make a Titan run. My truck qualified and finished second against a field of trucks with 17.5 brushless motors and all sorts of different tire combos. I would say the majority of advantage of the 17.5 trucks was the tires. My truck was 100% out of the box. So I would say my Titan held it's own, but then again I've seen some guys out there with some insanely slow Titan motors.
    Springfield, MO
    3,679
    Quote Originally Posted by jakeson81798 View Post
    this is a myth.....
    Springfield, MO
    3,679
    Quote Originally Posted by redbarton View Post
    This is right... about a "17.5" brushless motor. Those are usually 2000-2300 kv.... you gotta gear them up a lot taller than the titan, but the overall performance will be close.
    RC Qualifier e-revo's Avatar
    South FT Worth
    351
    the titan 12t 550 can go 30mph
    Jan 2008
    South Jersey
    8,407
    I guess it was about time for this thread to get revived.
    13,773
    Well to answer the 3-and-a-half year old original question, I have found this motor lately and want to try it out:
    https://www.ssl-stormerhobbies.com/c...ns&pn=TRI10153
    I think it may just match or better a titan with proper gearing. *sensored esc required*
    Ya can't polish fertilizer...
    South of St Louis
    6,280
    hee hee hee this post is old.
    Feb 2016
    3
    I'm in need of a new motor to really thinking about just getting another titan I had the two largest gears it came with in it and it was hard to turn the gear by finger they literally had no slack and I know that's what caused my titan t 12 to smoke badly so I turnd it off disconnected the battery took a damp cloth to cool the motor left the optional pinion in took out the optional spur gear and stock back in took it out 3 more times hauled like a champ and now I know the motor is dieing just got the rustler last sat. I believe the t12 is a good motor and I just abused it horribly IF THERE IS A MOTOR AROUND 20 -40 $ THAT IS BETTER IN EVERY WAY let me know other wise I'll just buy 2 more titans
