Results 1 to 11 of 11
    Feb 2008
    822
    Servo saver,,,,,
    I put a new radio in my Slash so I took off the servo saver to get my steering centered. Well that wonderful spring came out after running it this morning. Is there a trick to getting it back in? Does anyone make a better servo saver? I have never had this happen on any of my other Traxxas kits. Also, if I order a stock servo savo does it come put together or does this involve more spring wrestling. Thanks.
    Feb 2009
    here
    392
    sigh. i hated when that happened to me. it took me like 20 minutes to get it back in.
    ...true story.
    Mar 2003
    Wherever the road takes me.
    37,407
    If the spring comes out once, it will be easier for it to come out again. The servo saver blows apart to protect the servo. It usually happens when you hit something with the tires, but you can loosen it up during a crash and have it fall apart later.
    I recommend the Kimbrough 121 if you still have the factory plastic geared servo. If you have a MG servo, get the 124.
    Feb 2008
    822
    I didn't hit anything. lol I had never had one of those come apart like that. I put in a new receiver and took off the servo saver to get the wheels centered and ran it alittle on the floor at work and noticed the spring coming out. I have several Traxxas kits and this is the first time I have had this problem. I ordered two more stock servo savers at my lhs. Is the Kimbrough 121 nicer?
    Apr 2006
    411
    Funny, this just happened to me today with the servo saver on my Slash. The same servo saver has been running without problems on my 2" extended FLM Pede for years now. I wonder if the new ones are weaker. I ordered the Kimbrough 121 as a replacement.
    Mar 2007
    Durham, N.C.
    1,303
    If you have a metal gear servo, get this: http://www3.towerhobbies.com/cgi-bin...?&I=LXS361&P=7
    It's the one thing I can think of that I haven't broke yet.
    I WILL spank a nitro any day...guaranteed. :)
    Feb 2008
    822
    Quote Originally Posted by Rusty XL-5
    I am using the stock servo. Would this work with that?
    Mar 2003
    37,407
    Quote Originally Posted by Redman65
    It has a slightly stiffer spring, so it doesn't blow apart as easily as the factory servo saver. But if yours didn't blow apart from running into something... I don't know what to tell you!
    Don't use the 124 with a plastic geared servo, as the spring is too stiff. You'll strip servo gears.
    Bad Kreuznach, Germany
    486
    cooleocool,
    How do you know if you have MG or not? I'm running the stock 2075 and cannot for the life of me find any refrence to the gears...
    Thanks in advance!
    Aut viam inveniam aut faciam
    Mar 2003
    37,407
    Those gears are plastic.
    486
    Quote Originally Posted by cooleocool
    Thanks for the information.
