Results 1 to 23 of 23
    Feb 2009
    Oakley, CA
    192
    Life Expectancy of a 3.3?
    I've got my friends Slayer here at my house, and it needs a new piston and sleeve. I was just wondering what the life expectancy of the 3.3 motor is...
    1/16 E-Revo VXL
    1/16 Slash VXL
    Slash
    Jun 2008
    St. Louis, MO
    380
    5 tanks to 7-8 gallons
    I'm so far behind, it looks like I'm winning.
    Feb 2009
    Oakley, CA
    192
    Wow, that's it? Thanks for the help.
    1/16 E-Revo VXL
    1/16 Slash VXL
    Slash
    Feb 2009
    Oakley, CA
    192
    So what can I do to make sure that my motor lasts for a long time, cause I don't wanna be spending $80 every month rebuilding the motor...
    1/16 E-Revo VXL
    1/16 Slash VXL
    Slash
    Jun 2008
    St. Louis, MO
    380
    its actually a very reliable motor. I dont even run 2.5 gallon through in the whole season. Most .21 motors that I have seen and dealt with may last around 5 more if your lucky
    Marshal carraig042's Avatar
    East Tennessee
    6,752
    1. Break in properly
    2. Do your after run procedure if it will sit for more than a day or two.
    3. Make sure you maintain a good tune.
    If you do all of this you can get 8+ gallons on an engine.
    -Brett
    4wd Sportmaxx 3.3
    Feb 2009
    Oakley, CA
    192
    I havn't gotten my Slayer yet, so all this Nitro stuff is new to me. I know you have to break it in, I know how to do that, but what is the after run procedure?
    1/16 E-Revo VXL
    1/16 Slash VXL
    Slash
    East Tennessee
    6,752
    You can use an after run specific oil, or you can use wd-40. After the run you will squirt one of those down the carb and glow plug hole, then turn the engine over for a few seconds. You do this 2-3 times. Then you make sure that the piston is at BDC. (Bottom dead center) The instruction manual that comes with your Slayer will tell you how to do it. Read the manual twice (especially the break-in and tuning part) and be sure to watch the dvd.
    Edit: Here is a great thing to look at that has more detailed information as far as tuning goes.
    -Brett
    4wd Sportmaxx 3.3
    Dec 2008
    Gettin' Lucky In KY
    3,916
    after run is a must. the reason for this is because the fuel is a methanol based fuel which creates alot of condesation b/c of it's high evaporation rate. condensation will cause the steel internal parts to corrode over time unless you flush it out after you run it (after run). all you're doing is flushing the excess fuel out of the engine with either WD 40 or after run oil.
    i actually use both. i'll do WD 3 times then the last time i'll put after run oil in it and let it sit.
    Feb 2009
    Oakley, CA
    192
    Cool, thanks for the help everyone.
    1/16 E-Revo VXL
    1/16 Slash VXL
    Slash
    Dec 2008
    Gettin' Lucky In KY
    3,916
    run it till it blows and then use the ERP.
    Nov 2008
    Montreal, Canada
    181
    Quote Originally Posted by carraig042
    -Brett
    i agree with you!!
    i would say at least 6 gallons but 8-9 sounds right
    I have 15 r/c's and my slayer & slash are the best
    Feb 2009
    Oakley, CA
    192
    After I replace the piston and sleeve, I have to break it in again, right?
    1/16 E-Revo VXL
    1/16 Slash VXL
    Slash
    Dec 2008
    Gettin' Lucky In KY
    3,916
    Quote Originally Posted by DK-Freestyle
    yes you do.
    Nov 2008
    somewhere in PA??
    525
    You can re pinch the piston and sleeve..Then break it in again and you'll get about 3 gallons out of a re-pinched sleeve.....
    Get a hold of dalefuller1 if you need to get a sleeve pinched or have questions about it..he does my sleeves for me.
    Race when i want and where i want.......
    Dec 2008
    Gettin' Lucky In KY
    3,916
    re pinched sleeve? never heard that before. what does that mean?
    Nov 2008
    somewhere in PA??
    525
    Well, you take the sleeve and put it in a coupler and squeeze the sleeve to make a tighter fit around the piston, makes it almost like new.The sleeve is brass so it can be pinch.
    Dec 2008
    Gettin' Lucky In KY
    3,916
    oh ok that's kind of what i was thinking. man you gotta be precise to do that tho. i mean real precise. the gap is miniscule in ABC motors.
    Nov 2008
    somewhere in PA??
    525
    I'm going to try to do some soon, it takes time and patience to do one.
    You don't have to be very precise, as long as the piston is able to slide up and down your good, you can over pinch as sleeve too.
    Mar 2009
    136
    Quote Originally Posted by NitroBurner9
    I must be lucky, I am 2 years on the same motor. Probly close to 10 gallons and running great. I leave them a little rich to help keep it alive. But knock on wood, I have never lost a 3.3 motor yet.
    I just wanna go fast!!
    RC Turnbuckle Jr. icepick832's Avatar
    Apr 2007
    Indian Trail N.C.
    3,294
    I guess I was lucky too. 10 gallons (well just under), and mine still had good pinch, was down for upgrades and decided to just retire it.. I beat on it pretty hard too.oh, and never once saw a drop of after run oil.
    Jun 2008
    Port Elizabeth, South-Africa
    4,562
    I don't see any reason for it to brake if you keep it lubed and do after run maintenance on it after every days play...
    If you don't like Nitro, you don't like anything!
    Jan 2009
    Beautiful Downtown North Carolina
    1,449
    sleeve pinchers
    my bash buddies and i were thinking about going in together for one of those,are they really worth it,need more info
    Master of Traxxas engine longevity....
