Results 1 to 2 of 2
    Jan 2009
    65
    Intermittent problem with reverse: solved
    Just wanted to pass this on. After running my Summit in water/mud I started having problems with reverse. I could move the throttle control all the way forward several times with no response and then suddenly reverse would engage. I cleaned the truck, recharged the batteries and was still having the problem with reverse. Finally I blew out the motor with compressed air and a bunch of grass came shooting out. After that reverse was fine.
    Not really sure what the explanation is behind this…
    Nov 2008
    New Jersey
    205
    I notice this too. My emaxx's evx2 does the same. I notice it happens when she's covered in snow or realy wet and dirty. I'll hit forward two or three times and then it will go in reverse. When dry I hit brake then forward one more time and everything would be ok again.
    Sig edited for content.
