    Dec 2008
    487
    Question Understanding brushed and brushless specification
    Iím trying to understand the classification or how to categorize brushed and brushless motors. For instance the power output of the motor (turns, Kv rating, so on and so forth). I have been doing some searches but have not found all of what I am looking for. If someone could redirect me to where I might be able to find this information or could tell me would be greatly appreciated.
    -----The iceage is over, embrace the voltage.-----
    Dec 2008
    487
    I hope my question isn’t confusing.
    Aug 2008
    amherst, MA
    757
    well, what exactly do you want to know? are you asking what kvs and turns mean?
    Emaxx 3905 FS in the market place.
    Dec 2008
    487
    Sorry if I wasn’t clear but yes someone clarifying up Kv ratings and other information that brushless motors are rated by would be greatly appreciated. I'm rather certain I know what turns mean (Which applies to brushed motors, more turns more torque less rpm’s, less turns less torque more rpm’s, correct?).
    Aug 2008
    amherst, MA
    757
    alright kv is rpm per volt. this is the voltage total of your batteries times the kv equals the motor rpm. higher voltage requires lower kv so you dont push the motor to too high rpms
    Mar 2007
    near New Orleans
    5,905
    Check this site out for a good explanation of brushed vs brushless motors.
    http://www.hooked-on-rc-airplanes.co...rc-motors.html
    "KV is the voltage constant. This is how many RPMs the motor wil turn for each volt applied. For my 5s 2200 Kv set up means the motor spins 40,700 RPMs, assuming 1005 efficiency.
    E-Maxx Neu1515 1y/MGM 5s
    Jan 2009
    France
    769
    Quote Originally Posted by mkrusedc
    Thanks for the link. I went through this and I could not see any reason why a brushless motor could not run in water. Is this correct?
    If yes, then the only thing needed to make a waterproof BL truck is a waterproof ESC. I saw a link a few days ago on one of these.
    Last is the problem of the batteries. I understand LiPO and water do not mix well. That means using NiMH on BL, and that's going to be a problem given the current drain of a BL system.
    E-Maxx on NiMH / Savage Flux on LiPO
