Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 481 to 520 of 607
  1. #481
    Mar 2014
    14
    Recently joined this commnity of brushlessness.....here goes my erbe
  2. #482
    Feb 2014
    San Diego, CA
    66
    Just put this together
    If it ain't a Traxxas, it ain't fast
  3. #483
    Jan 2014
    102
    Nothing special, just installed sway bar, wheelie bar and newly painted body shell : )
    Gonna take her out tomorrow for a one fine ride : )
  4. #484
    May 2010
    315
    Just painted up my new 69 Charger body and took it for its first run today.
    2x 2wd Slash|Slash 4x4 PE|MM E-Revo|Grave Digger
  5. #485
    Jan 2014
    Lake Charles, LA
    63
    Here's mine. Oxford white body (same color as my Ford Raptor). I designed my graphics in CAD and cut them out on my wife's Silhouette vinyl cutter. Came out okay, looks better breaking the white up for sure.
    Satin White/Light Blue ERBE, Spartan & MERV
  6. #486
    Nov 2013
    Missouri
    229
    My erevo
    Slash 4x4 & E-revo brushless
  7. #487
    Feb 2014
    San Diego, CA
    66
    Just painted up a new body
  8. #488
    west virginia
    93
  9. #489
    Athens, Greece
    620
    <3 Traxxas~Align~Ducati~Lib-tech~JacksonGtrs <3
  10. #490
    Feb 2014
    Australia
    166
    [IMG]E-Revo by .Chris.K, on Flickr[/IMG]
    [IMG]. by .Chris.K, on Flickr[/IMG]
  11. #491
    west virginia
    93
  12. #492
    May 2014
    83
    Work in progress.
  13. #493
    May 2014
    Back into the hobby :)
    Just got a erevo brushless put a sct body on it summit bumpers. Went strait for 3s lipo got it some proline trencher tires more mods to come.
  14. #494
    west virginia
    93
    got some road rash today
  15. #495
    May 2009
    Edmonton, Alberta
    3,663
    Started painting a new prographics for my ERBE last night, finished it up today.
    First time using liquid mask, turned out pretty good except for a couple lighter spots in the Pearl Blue (in the tricky areas) that got washed out a touch by the silver metallic backer.
    (RAH)² (AH)³ + [ROMA (1+MA)] + (GA)² + (OOH)(LA)²
  16. #496
    411
  17. #497
    Apr 2013
    Russia\Sakhalin
    42
  18. #498
    411
  19. #499
    May 2014
    83
    New body b4 it gets nice and dirty!
  20. #500
    Oct 2014
    Hello from France
  21. #501
    Jun 2014
    5
    Comme promis voici le résumé en image de mon projet.
    J’ai repris il y a peu la RC (abandonné depuis 15 ans, mon dernier modèle un MP6 de Kyosho) et acheté un erevo, j’y ai apporté quelques modifs, comme les barres antiroulis, les culbuteurs et triangles progressives 3 et les tiges poussoirs en alu entre autre. Mais voilà je voulais encore plus de personnalisation, j’ai donc entrepris le petit projet de me refaire un nouveau revo.
    En dehors du moteur, des pignons et couronnes et des pièces en option j’ai quasiment tout changé.
    Pour commencer j’ai acheté des cardans acier TVR et MIP pour le centre.
    Changé les carter et corps de diff par des modèles en alu
    Là les galères ont commencé, les carter STRC ne sont pas du tout compatible avec les couronnes renforcées du erevo actuel, les sites de vente mentionne compatible erevo.
    Les couronnes étant plus épaisses, ça ne tourne pas et ça ne ferme pas.
    Donc une demi-journée à creuser au dremel en faisant très attention à ne pas abimer le reste.
    Voilà enfin ça rentre et ça tourne librement !
    Insertion dans les nouvelles cellules HR en alu de toute beauté, changement des roulements par des hybrides céramique.
    J’ai ajouté les noix options pour les triangles allongé P3 de l’arrière.
  22. #502
    Jun 2014
    5
    Montage des triangles RPM
    Montage de la boite an alu avec aussi changement des roulements par des hybrides céramique.
    Pose de la couronne acier 65 et du pignon 15 RR, j’ai été obligé de limer le cache en alu au niveau du passage du roulement vu que celui de RR est surdimensionné.
    Pose des cardans centraux MIP
    Pose du sauve-servo avec ressort renforcé pour servo à engrenages métalliques.
    Pose des plaques et caches alu du dessous.
    Bon là je n’ai pas pris les photos du dissipateur avec ventilo, c’est un modèle Hobby King que j’ai légèrement déformé pour l’adapter parfaitement au Castle Mamba 2200, j’y ai bien sur mis une pâte thermique collante ARTIC SILVER 5. Attention après avoir fait le mélange vous ne disposez que d’une minute maxi en fonction de la chaleur pour la pose
    Une partie bien prise de tête l’intégration du CCBEC Castle, car pour encore compliqué le montage j’ai monté (comme sur ma précédente carrosserie) un système d’éclairage automatisé. En résumé quand j’accélère les phares avant s’allument à 100%, quand je freine les phares arrières …, quand je tourne les clignotants, quand je recule les feux de recule etc…
    Donc j’ai fabriqué des Y et câbles de dérivation.
    Et pour connecté simplement le CCBEC aux batteries, j’ai acheté un détecteur de puissance monté sur une prise gigogne, et tout simplement soudé les fils du CCBEC dans cette dernière, propre et bien intégré. Seul petit hic, le câble est un peu court.
    Tout est rentré en forçant un peu dans la boîte étanche, ouf!
    J’ai monté des embouts alu HR (que j’ai aussi peint) sur les corps en alu d’origine des amortisseurs, j’ai modifié les pistons d’origine par les pistons variable, mis de l’huile plus épaisse et changer les ressorts.
    Ça m’a posé énormément de problème, je déconseille fortement les options alu HR, je pense d’ailleurs par la suite remettre les bouchons d’origines avec les protections bleus pour les pistons.
    Je vais commander les ressorts « noir » 6,4 les plus durs pour l’arrière.
    La boîte ainsi que le cache couronne an alu, j’ai poncé et peint en orange (avec de la peinture pour vitrail) le support moteur.
    J’ai remplacé les servo d’origine par des Sanwa ERS-962 étanches (Vitesse : 0.11sec Puissance : 25.3 kg) branchés donc en direct sur le CCBEC en 7,4V.
  23. #503
    Jun 2014
    5
    J’ai remplacé les tiges en acier des barres antiroulis par des tiges en alu rouge.
    J’ai posé des portes fusée HR alu-carbone.
    J’ai aussi bricolé des barres de renforts avant avec des tiges alu de slash.
    J’ai également peint les culbuteurs avant en alu.
    Pose des protections et pare-chocs T-Bones.
    J’ai dû percer des trous pour adapter les protections des triangles avant.
    Concernant la carrosserie c’est une HPI Dogde Charger de 69
    J’ai donc intégré la câblerie pour l’éclairage, avec une boîte étanche pour le contrôleur relié au transmetteur.
    Pour les phares, j'ai posé des caches à l'intérieur sur les différents phares au moment de la peinte, j'ai respecté les éclairages de la vraie.
    J’ai renforcé la carrosserie à l’intérieur avec du ruban adhésif et de la colle liquide pour protéger les fils et l’optique, j’ai aussi rajouté des tiges de métal (cintre) et à l’extérieur avec un vinyle adhésif très épais (Helicopter Tape)
    Ça n’est pas beau et ça gâche l’esthétique mais vu ce que va manger la carrosserie, c’est indispensable.
  24. #504
    Jun 2014
    5
    J’ai aussi peint les jantes et les vis pour me rapprocher le plus de la vraie Général Lee.
    Toute la visserie d’origine a été remplacé par de l’inox.
    Voilà je pense avoir dit l’essentiel.
  25. #505
    Oct 2014
    199
    Just picked up my first erbe.got some 500 may 2s lipo's to go with it. Lots of fun but want some 3s to start breaking stuff lol. Here's some pics, just a wheelie bar and long travel rocker set so far.
    http://
    http://
    http://
  26. #506
    Oct 2014
    199
    *5000mah lol
  27. #507
    west virginia
    93
  28. #508
    Oct 2014
    Sound Beach, NY
    38
    Only mods are the wheelie bar and lipo 2s. This is after a good break free bash and then a bath.
    this pic i had to send to traxxas so they can replace my tires as they came unglued after one run:
    Got some trenchers and a new body coming so will post new pics soon.
  29. #509
    Oct 2014
    Sound Beach, NY
    38
    Got the new Charger body and the Trencher Tires, next i'll outline the letters on the tires.
  30. #510
    Apr 2014
    10
    E-Revo Brushless Edition Gallery!
    Specs, MXL-6s, CC 2200Kv Motor, CC BEC,
    Bluebird 35Kg HV Servo, Spektrum DX3S Tx,
    SR 3300T Rx, Working Telemetry. Center Diff,
    Summit Shafts, Ceramic Bearings,
    HPP Hexes & Motor Brace. Badlands, Desperado`s
    Traxxas Maxx, Geode`s. Trencher X, Desperado`s,
    & Big Joes On Tech 5. 18/54 Gearing.
    Orion 2s 6500mAh 90C
  31. #511
    Oct 2014
    Sound Beach, NY
    38
    Painted white lettering
  32. #512
    Oct 2014
    199
    Painted the stock body with some hot hues extreme green and threw a couple decals on it. Was a little beat up when I painted it but I think it turned out well. Got castle link and some spc 3s lipos! The batteries barely fit but look like they will be stupid powerful. Also dyed the chassis black.
    http://
    http://
    http://
    http://
    http://
  33. #513
    Oct 2014
    Sound Beach, NY
    38
    so I bought the above body (in my last post) finally took it out, just on the street and grass, no flips, no crashes, maybe a few wheelies because it's impossible not to and look what happened to this body. So far, the seller has not offered anything probably because it says no refunds or returns. But man did he do a poor job.
    first is the original:
    than after one non-bashing run
  34. #514
    Feb 2013
    Hungary
    10
    it was born as an ERBE, but now, it's an E-Revo 5TT:
    greetings from Hungary!
  35. #515
    Jul 2009
    SF Bay Area, CA
    369
    my new and too clean erbe...
    badlands, wheelie bar, 4s for now...
  36. #516
    Jul 2009
    SF Bay Area, CA
    369
    took a couple more before I ran it last weekend.. all clean.
    love how those badlands premounts give it a wider stance.
  37. #517
    Jan 2015
    Sweden
    My E-Revo got quite a bit heavier after bashing around in the snow & slush today here in Stockholm. Really quite fun & varying to drive on mixed snow/ice and wet tarmac with gravel.
  38. #518
    RC Racer waqrrr's Avatar
    Jan 2015
    Sweden
    232
    Quote Originally Posted by repilur View Post
    Yes, the snow is fun to bash around in
  39. #519
    RC Turnbuckle Jr. brushlessman's Avatar
    May 2007
    Kerrville Tx
    5,001
    Yes i have returned after roughly 5 years! My e-revo is still alive and well!
    Here's a recent video of it!
  40. #520
    Feb 2015
    245
