Results 1 to 12 of 12
Thread: single 700 HO?
    Jul 2008
    Texas
    124
    single 700 HO?
    how do you get the single 700 HO conversion from kershaw? I dont see it on their site. or do you just need to get the motor and nothing else?
    T-maxx18tz,Rustler,T-maxx,Jato,E-revo,Merv,Slayer
    Oct 2007
    Jacksonville, FL
    178
    Just the motor, pinion(s) and mounting screws. It will fit perfectly fine in the forward rotation side of the motor mount. Just put a peice of tape or something over the hole where they reverse rotating motor was.
    E-Revo-MMM V3/Tekno Neu 1515 1YF
    Rustler VXL-3s
    Oct 2008
    In the shadows...
    204
    Look a little harder:
    http://home.ptd.net/~kershawd/Kersha...Cs-Brushed.htm
    You will also need a 5mm bore 32pitch pinion, and some ceramic disc capacitors unless you have a digital radio (to reduce RF noise).
    I am SuicideNeil, please dont shoot.
    48
    Quote Originally Posted by thedude
    The motor comes with the screws and capacitors,so all you will need to buy extra is the pinion.
    Don't be a Keyboard Cowboy!
    Jul 2008
    Barcelona, Spain
    93
    Quote Originally Posted by Tread1
    Yes, I have bought only the motor, and one 32p 0.8 mod 20 teeth (they are on the way ), I have read also that the motor comes with screws and capacitors.
    I hope it will make my wait for brushless easier (possibly MMCombo or similar)
    Jun 2008
    63
    I had Dan do the soldering for me. It went in without a hitch.
    http://monster.traxxas.com/showthread.php?t=433805
    E-Revo
    Novak HV Pro 6.5
    MaxAmps 8000 2S Lipos
    Jul 2008
    Barcelona, Spain
    93
    Well, my 700HO arrived but with no mounting screws, i'll have to find ones that fit because the ones in the stock motors don't.
    Do you know the measurements of good mounting screws?
    I have to solder the capacitors having a Futaba 2.4 GHz?
    Thanks
    Jul 2008
    JAPAN
    24
    When I mount 700HO to my e-revo, I use this screw.
    http://www.rc-square.de/english/squa...ews-spacer.php
    4x10mm Hex Countersunk Screw (6 pieces) STR-412
    Oct 2007
    Jacksonville, FL
    178
    Quote Originally Posted by Smashwings
    Thanks
    I found some at Home Depot. They are in the Metric under M4. If you find some, I would go ahead and stock up. That is the same diameter as some of the other screws on the E-revo.
    Rustler VXL-3s
    Jul 2008
    Barcelona, Spain
    93
    akapuku, your link is for 12mm long and your comment say 10mm.
    (for all) Which would be the most appropiate, M4x10 or M4x12 ? (both countersunk)
    Jul 2008
    82
    You can use the screws that tie your front bumber into the mount. These are a good example. For now, you should be able to use two of the eight screws that hold the centerline skid plate until you can find some. I scavenged some screws from my Revo 3.3, but you get the point. Next time, just be sure to remind Dan you will need some screws.
    Jul 2008
    JAPAN
    24
    I check my mount screw.
    Sorry, screw is M4x8. Please use countersunk M4x8.
