Results 1 to 10 of 10
    Aug 2008
    Canada B.C.
    332
    Gearing Question?
    Is there any Gear combos that shouldn't be used like 14/90 or 23/83
    Nov 2007
    CHILLIWACK CANADA
    45
    use what ever you want, just watch your temps!!! it all depends on where and how you drive.
    if it doesn't melt,its not fast enough!!
    Jun 2008
    862
    Someone around here swears by 16/90. I use 16/83 or 16/86. They are so cheap I just bought two of every traxxas pinion and spur and screwed around til I found something I liked. Only takes about 2 minutes to change them out and set the slipper once you've done it a couple times.
    Aug 2008
    Canada B.C.
    332
    Quote Originally Posted by dextermeth
    what do you mean by set the slipper clutch i thought it was suppost to be 1/2 turn is there more
    Jun 2008
    862
    Well, the slipper is adjustable for a reason.
    But what I meant was that each time you change a spur, you'll be redoing the slipper by default. They are attached to each other afterall. After a few times you'll know where it is supposed to sit thus only taking a few minutes to change out a spur/pinion.
    Mar 2003
    Wherever the road takes me.
    37,220
    Gearings that you shouldn't run will depend on the motor that you are running. I wouldn't go above the included "speed" gear. Off road, I wouldn't go above the factory installed gear.
    Aug 2008
    Canada B.C.
    332
    my new motor the instructions didnt say anything about any gears i shouldn't use
    Amherst New Hampshire
    1,671
    What is the new motor?
    Dontworry,thelightathendofthetunnelisatrain!
    Mar 2003
    37,220
    Quote Originally Posted by FOX22
    That's probably because different gearings will be used for different types of vehicles. If the motor was installed in a touring car, it could be geared much higher.
    Aug 2008
    Canada B.C.
    332
    its a Formula Pro BB 17x2
