    85
    velineon doesn't respond?
    sometimes when i pull full throttle, the velineon motor doesn't respond, but when you give the truck a little nudge it'll go. doesn't happen all the time, but enough for it to be a nuisance. any ideas?
    Aug 2008
    49
    try reprogramming the esc with all trims at 0 again and check all your bullet connectors to make sure they're all still secure. i had this problem with mine and it was a combination of the two.
    Gettysburg
    350
    If you are running nimh's make sure the LVC is off - my vxl acted like this when running nihms with the LVC on.
    Jun 2008
    Lost & Found on the intersection of Walk & Don't Walk
    1,614
    This an old esc, been used? Mine did the same thing.... cut out and a push would help it go, sometimes if you walk close giving it gas it does............. if it is used and not brand new, contact traxxas......
    btw, does it beep when you give it gas and it doesnt go.
    NOBAMA '08 Welcome to the Greatest Dprsn.
    85
    it's on a 3s 5000mAh lipo, on lipo mode and brand new. it doesn't beep when i give it gas when it doesn't go
    Gettysburg
    350
    Did you reprogram?
