Results 1 to 25 of 25
    Jun 2008
    7
    Need new tires....any suggestions
    Well I have run through the first set of tires on my Slash and was looking for some rims and tire suggestions. I am looking for a good set of offroad tires. Any help would be appreciated. So far I have found these.......and feed back on these would be great too.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXRGT1&P=M
    http://www3.towerhobbies.com/cgi-bin...?&I=LXEXA3&P=M
    Jun 2008
    Orlando, FL
    447
    New tires already!!! WOW! you guys are literally running the wheels off your models!!!
    you must have been running non stop since release
    RC Turnbuckle Jr. 31794ty's Avatar
    Nov 2007
    Marietta, Georgia
    3,822
    If your running brushless, beadlocks are not a good idea. They come off of the rim quite frequently.
    Stampede VXL Mini-T Nitro Stampede RC10T RC10B4 FT
    17,121
    Rocksters come in one offset only, so your rear will be wider than your front. The Geolandars are ST tires, so will probably be at least a half-inch shorter than the stock tires. How about Moabs or Flatirons? And why would you need new wheels as well as tires? Are you not keeping the stock 5-spokers?
    Alt-248 on the number pad =
    Apr 2008
    Eugene, Oregon
    263
    If the beads on the stock wheels are the same as the bead on the geolandars, I bet the stock wheels and the geolandar tires would look pretty slick. As long as it fits under the fenders and doesn't rub that is.
    Jan 2008
    Austin, TX
    201
    Moabs & Flatirons are about 5" tall, unless you do something to raise the body the tire rub will be massive. Stock tires are around 4.3" tall. Geolanders are a good height, just wider...
    Dirk
    Slash,#3905 E-Maxx,Rustler,Stampede,9 more
    Jun 2008
    Planet Earth
    139
    i think someone should mount the Geolanders on RPM Revolver wheels (the narrow wheels that are made for crawlers). I personally think that setup would be perfect.
    I however am on my second set of tires as well .... but just bought some of the OEM tires/wheels from Traxxas. my first set of tires is completely bald..... i havent had so much fun with an RC in a longgggg time. ive been running the wheels off of it.
    VXL/ 40wt frnt, 60wt rear/ RPM front end
    Aug 2005
    uh, I thought that you could help me figure that out.
    318
    Erikson and Montana Scale Designs both have more than a few nice 2.2 beadlocks, and the MSD ones are some of the best in the rock crawling biz. as for tires, I still stand by my suggestion of a set of Xtreme RC Hobbies narrowed dirt works, or a set of their narrowed Imex Claw Dawgs. (not the super narrow ones, as they are really really narrow) XRC also has a set of Axial Rockster beadlocks that are narrowed to 1" wide, which is the maximum recommended width for the narrowed dirt works
    GOT MY SLASH AND BEATING THE LIVING POO OUT OF IT!
    Jan 2008
    Austin, TX
    201
    Running wide tires on narrow wheels makes the sidewalls fold under during hard cornering. Slash tires are narrow to match the wheels. We don't have any options available right now for replacements that are similar in all dimensions, other than custom narrowed tires (not cheap). You can run 2.2 buggy rears, but they will be smaller and you will need to re-gear your Slash. Stadium truck tires will be close to the right height, but wider and will require fender trimming. Monster truck tires are wider AND taller, body lift and trimming needed. Crawler tires cause the same problems, and if you run them on narrow rims, handling will suffer. We need more tire options, for wheels we have the narrow crawler types that will work fine (RPM, Axial, Pro-Line Six Shooters, etc.).
    Dirk
    Jun 2008
    carrollton ky
    9
    some of you all dun wear out the tire that fast i have been on a lot of running on mine and still look good i play on a lot of black top if you all can post some pics of them i like to see them and for me i dont think the wide tires look right on there
    Jun 2008
    Orange County, CA
    786
    street set up
    Quote Originally Posted by gomer
    I've been experimenting quite a bit with tires on my Slash since I do run alot on black top. This may sound crazy, but with the brushless setup I've got in it, works great. Anaconda's from the Jato................. of course you kind of lose the scale good looks of the Slash, but with very minimum to zero rub, the tires are wider and the offset is different, they are just a little shorter than the stock Slash tires. Needless to say the handling on ashpalt and concrete is improved dramatically with these tires, I had an old set sitting around and they made a big difference.
    NOT A MAMBA, NOT A MAZDA--TEKIN RX8-problem solved
    Jun 2008
    Delaware
    1,234
    I've got rocksters with HPI sand thowers in the rear and sand runners upfront...I'm headin to the beach this week takin the slash and will give an update when I return.....does it matter which way I run the sand throwers?
    May 2003
    Michigan
    709
    Yeah you want to run them in the direction that makes them cup the sand when they spin.
    RadioControlDecals.com
    Custom Name Decals & More
    Jul 2003
    nevada
    57
    These should be a good alternative.
    http://www3.towerhobbies.com/cgi-bin...&I=LXUM92&P=ML
    Any place, any time , any task!
    Jun 2008
    mountains of north jersey
    57
    I agree with Mr. !Bungle here.. There are not to many options. Just like full scale rides everything is a compromise. Want the scale look? your going to get lots of sidewall flex, great for crawling and off roading. For better handling I would go with a bigger wheel and smaller sidewall like sellinchevs did.
    This is why I am curious about Skulli's bandit setup with 1/8 scale wheels. These are actually close in overall outside dimensions to the slash wheels/tires (about 1.5 in wide / 4.1 - 4.25 dia). You have to run adapters to use 1/8 wheels, but I bet they would be a great blend of handling and off road grip - not sure about the offsets though....
    http://www3.towerhobbies.com/cgi-bin...?&I=LXHEN5&P=7
    Question Everything
    lubbock, TX
    348
    man if those would fit, surely a set of badlands would, didnt think of goin to 1/8th set up, more ground clearance as well, that would be the ultimate, if you could find a realistic lookin set of wheels now....
    Platinum E-REVO
    FT T4 - Novak Havoc
    May 2003
    Gering NE
    233
    E-savage tires might work. Bigger than truck tires and smaller than monster truck tires. Not sure what size the wheel hexes are.
    Nov 2007
    Maxwell, TX
    403
    Quote Originally Posted by Dukelion
    I have that same setup now...
    I can tell you that on my VXl Slash that I have had a problem with the tires pulling out of the wheels. You will also need to raise the body mounts and trim the fender wells to keep them from rubbing. You may also need to flip the bolt on the front steering blocks to keep it from rubbing the beadlock bolts. They hook up well and look nice, but not that pratical for BL systems.
    If it's wet, sticky, and not yours..DONT TOUCH IT!
    Jan 2008
    Austin, TX
    201
    Quote Originally Posted by duneordie
    Chrome 5-spoke w/bolt heads around rim:
    http://www3.towerhobbies.com/cgi-bin...?&I=LXHWJ0&P=1
    And for a less realistic, but very sinister look:
    http://www3.towerhobbies.com/cgi-bin...?&I=LXUAB9&P=1
    and "routergod", Knuckles are exactly the 1/8th scales I'd pick!
    1/8th Badlands on the black wheels for bashing, less scale but would work great.
    1/8th Moabs as a possibility, as well...
    Quote Originally Posted by mr_resistible
    from Tower: HPI E-Savage Tires: 5.4 x 2.8" (138 x 70mm)
    Way too big, my man...
    I believe they use 14mm hexes, too - like a Maxx
    Dirk
    Jan 2008
    Sioux Falls SD
    84
    I ran my Slash for 4 days and needed new rear tires. Bald around the centers of the tires. I have a Velineon system in it with 5000 mah and now am running Jato tires and rims WOW is this fast
    Speed is not expensive but it can be costly
    Feb 2004
    KSU land
    1,065
    post a pic of a full set of anaconda's on a slash would you
    Jun 2008
    57
    Nice picks Bungle - I didn't spot those rims. When the time comes I'll post pics.if I decide to do it.
    I *think* these are the right adapters -http://www.neweramodels.com/item.cgisession_id=fhaypnjmotvbueugoglihcejlowgjhj t&part_id=8538
    Question Everything
    Jan 2008
    Austin, TX
    201
    Yeah, that's the set of adapters I was checking out. $35 is a bit steep, but I guess you can reuse them over and over. My LHS has some new "old" Panther 1/8th tires for 50% off that I may try, just to lower the total cost of converting the Slash. I'll look for a cheap set of rims, too.
    My Maximizer 17mm adapters that I use on my E-Maxx were $25, and the washers they came with were plastic! Recently I got the new Revo Platinum splined 17mm hubs for $22 because they are so much nicer, haven't put them on yet... man, does this stuff add up or what?
    Dirk
    Jun 2008
    Seattle
    767
    I am looking for some better "loose:" dirt traction tires. I am going to try the HPI Geolander/ Rockster combo. But i really want to keep the stock look and eat up some dirt at the same time. Maybe some Slash rims with some good tires is the right combo.
    any ideas?
    EREVOs, Slashes, 1/16 Slash, EMAXX, VXL Villain
    Jan 2008
    17
    Geolanders mounted on 4 stock 3772 Traxxas rear rims fit very nicely inside the Slash body with no more than normal rub. They maintain the stock width but do have a wider contact patch.
