    May 2007
    31
    Rustler gear ratio
    Hi i am converting my bandit to a rustler and i am trying to find a better gear ratio i am using a Team Orion Method R 19x2 motor driving hpi 2.2 mesh wheels and i am running proline road hawgs and i was wondering what the best gear ratio would be for it to give it higher top speed , also my friend is running a tamiya tz in a traxxas rustler and his is realy quick and he is running a 23 tooth pinion and the stock spur and my motor has the same rpm so should i just use the same ratio ?
    Mar 2003
    Wherever the road takes me.
    37,433
    I'd try a 17-tooth pinion with the stock spur gear.
    May 2007
    31
    but my friend uses that gear ratio and his is perfect high speed decent acceleration and long battery runs
    Mar 2003
    37,433
    A good rule of thumb for a starting point is to subtract two from the number of turns the motor is (for 540 modified motors).
