Page 11 of 54 FirstFirst ... 91011121321 ... LastLast
Results 401 to 440 of 2133
  1. #401
    Jun 2003
    Cen Cal
    1,479
    OBM ran this one on his Revo back then: http://www2.towerhobbies.com/cgi-bin...?&I=LXFAZ8&P=7 Pictures are on page 1.
  2. #402
    RC Turnbuckle Jr. IAMI's Avatar
    Jan 2001
    Post Falls, Idaho
    3,041
    It was custom made in the Traxxas R&D Dept.
  3. #403
    Jul 2006
    BC, Canada
    486
    I wonder if the T-Maxx header might work.......flip it around.
    Where's the 1/8 Revo?
  4. #404
    Dec 2004
    lewisville
    80
    snapped the rear break linkage on my revo today :(
    has anyone else broken the rear break linkage?
    i was having a blast at SRH and boom, no rear breaks.
    the rear brake rod broke right about in the middle.
    any ideas?
  5. #405
    Jul 2005
    Bay Area, CA
    41
    I'm curious as to why the Revo runs really thick diff oils. I run 2-10k range in my front/rear diffs in my truggy, and 10-30k for the center. What makes the Revo so different?
  6. #406
    Jan 2006
    okc
    2,210
    Tranny, and it has half the gears as most diffs. I'm running 40-400-40. I saw in slaydens set-up sheet he's running 100-500-50. I haven't gone up that high on my front yet. I really didn't notice any difference above 400k. I do really recomend going up in the rear thou, it will level out your rear when off power.
    As far as the rear brakes breaking I haven't had any trouble and I haven't heard of anyone having problems yet. I set mine up with a star servo horn, it gave me more options on my brake bias set-up. It also takes the rod off of the tranny so there is no nothing for the rod to inpact.
    Hip Pocket Racing
    revo-world.com
  7. #407
    Jan 2001
    Post Falls, Idaho
    3,041
    Quote Originally Posted by atmo
    Atmo, what do you mean by this? I have never heard of "level out the rear".
  8. #408
    Jan 2006
    okc
    2,210
    Well i was breaking in a motor and noticed when i let off the throttle my rear end would squat, but when I stopped it was level. So it got me thinking about my rear diff. i went up on the weight at the time i was running 7k rear. I put and extra diff in that had 30k in it and the problem stopped. Now when I let off the throttle and it's rolling under no power or brake the rear is level. So going into a turn off power and off the brake it's level. It seems to work around the 30k mark. I'm going to try 50-500-30 and see what happens. I never notice this before the CD so i don't know if it's a CD thing or not.
    Hip Pocket Racing
    revo-world.com
  9. #409
    Jan 2001
    Post Falls, Idaho
    3,041
    Are you running a 3.3 chassis with the standard rear a arms?
  10. #410
    Jan 2006
    okc
    2,210
    Yes and mainly .19 The only new thing I've put on my truck are the GRP tires with 1/2 offset great tire but there are no wheels available except some premounts on 17mm with 0 offset, so I've had to mod some 40 series and cut them way back.
    Hip Pocket Racing
    revo-world.com
  11. #411
    Jan 2001
    Post Falls, Idaho
    3,041
    That is where you extra sag is coming from in the rear. Weight shifts backwards with the extended chassis. Weight shifts forward with the swept back rear a arms.
  12. #412
    Jan 2006
    okc
    2,210
    Yes but when I went to the higher diff fuild in the rear it levels out when I let off of the throttle where as before it wouldn't level out until it came to a stop. Now she levels out around the 10mph mark off throttle.
    I going to try out slaydens set-up on the diffs tonight or tomorrow. i went ahead and put 100-500-50k and see how she handles.
    Hip Pocket Racing
    revo-world.com
  13. #413
    Apr 2006
    Philly
    315
    I keep stripping spurs like they are made of butter me and 18t run on the same track and we are going to try 17-40 Robinsons racing. But I figured my spur problem my lower screw on the under side of the chassis to hold alinment wiggled out.
    I run 100k in the center and I like it what do you guys think the best set up would be for the other diff 30-100-7 or 7-100-7 or 10-100-7 or 30-100-10
    YGR: JJ [URL="freewebs.com/younggunzracing"]freewebs.com/younggunzracing[/URL]
  14. #414
    Jan 2006
    okc
    2,210
    i don't like any of those options. I'm running 50-400-50
    I just put 100-500-50k "Slaydens set-up" I'll run her tonight and see how it goes. But imo anything under 400k is a waste of time. You really need to go up on both front and rear to get the right effect of the cd. tapping your tires helps with the over diffing but it still won't help the unloading problems. Haven't you noticed some shifting issues or she doesn't come out of the hole as strong. Are you running the 2.5r with 100k? I haven't tried it with the 2.5 but with the smaller motor she wouldn't unload as easy
    Hip Pocket Racing
    revo-world.com
  15. #415
    Apr 2006
    Philly
    315
    3.3 right now my set up is 30-100-75%of 10k
  16. #416
    Apr 2006
    Philly
    315
    I like it alot more control then the solid and It inproved my laps from 56 seconds-58 to 44-47 seconds you do the math
  17. #417
    Nov 2005
    55
    Couple of Q's........
    I am putting together another truck since I sold my old one about 4 months ago and it was a QT truck so the new one is gonna be totally different.
    Its gonna be a small tire bt-mt's, cf-mt's or boa's, short chassis, long rear arm, center diff ,rear brake truck, The old truck was a QT truck so I think Iam gonna have alot of work to get alot of off-power steering into this thing.
    Is there an easy way to put more antisqat in the rear????
    Where are you getting the 500K diff oil????
    ROY HELP!!!!!!!
  18. #418
    Apr 2006
    Philly
    315
    mugen makes it I believe
  19. #419
    Nov 2005
    55
    Found it........ Thanks.
  20. #420
    May 2006
    Hillsboro, OR
    77
    kyosho makes 500k fluid as well.
  21. #421
    Dec 2004
    Evington, Virginia
    12
    I ran the setup RDracing posted a few pages back. Let me tell you my truck was dialed. I turned some of the fastest laps I ever turned. Thanks RD racing.
  22. #422
    Jan 2001
    Post Falls, Idaho
    3,041
    haywood,
    You are welcome! More people should try it, glad to hear you have, and thanks for posting your findings!
    Roy
  23. #423
    May 2006
    Hillsboro, OR
    77
    misbehavin'-- How do you like the trc tires?? did they fit on wabash wheels? thanks for the info.
  24. #424
    Dec 2001
    Dallas, TX
    748
    What's up everybody??? Monster Madness in couple of weeks. Gotta go!!!
    http://www.rcmadness.com/entryforms/...er_Madness.pdf
    Hey Roy, what's up man? Hope things are going well. We missed ya this year at the USMT. The Nats are coming up though. Have you gotten in yet?
  25. #425
    Apr 2003
    Delaware
    1,994
    I'll be there at Monster Madness. First time for me. I heard it was awesome last year so Im definitally going up this time. Looking forward to meeting and racing with you Steve.
    Got nitro?
  26. #426
    May 2006
    76
    Can youlink me to that setup sheet please?
    Also why the big jump to 100k/50K? Won't that make it really hard to steer on power?
  27. #427
    Apr 2006
    Philly
    315
    I dont know steve I think you are going to have a tough time getting by nitrobasher he is a exetremely god drive I'd love to watch it.
  28. #428
    Jan 2001
    Post Falls, Idaho
    3,041
    Hey Steve, I am hanging in there. Yes, I was upset that I missed it too. Entry for Nats is going in the mail tomorrow.
  29. #429
    Jan 2006
    okc
    2,210
    RD Racing With the axle carriers are there any issues with metal to metal contact on the pivot balls and are they available in sets of two? I have had some issues lately with my axle carriers and more to the point my pivot balls poping out. The RPMs do not hold any better and might even be worse than stock.
    Hip Pocket Racing
    revo-world.com
  30. #430
    Apr 2003
    Delaware
    1,994
    I had one RD carrier that looked like the ball was about to pop through and Jackie sent me a new one. I think that one had a machining error becuase I've never had a problem since.
    Does anyone know a site that sells the 500k diff oil? I can't find it anywhere in stock.
    Got nitro?
  31. #431
    Apr 2006
    Philly
    315
    It isn't in stock any where from what I can see I have google'd it over and over still no luck.
  32. #432
    Jan 2006
    okc
    2,210
    Hip Pocket Racing
    revo-world.com
  33. #433
    May 2006
    76
    I found the setup sheet http://www.traxxas.com/support/pub/s..._ss_usmt06.pdf
    Seems like am extreme change. Last I read 50/300/30 was the way to go?
  34. #434
    Jan 2006
    okc
    2,210
    Right know I'm running 70-500-50 and this is the best set-up for my track. We have 2 sweeping straight awys that I can go full wood with the cd and a woop section that without the cd it's blip all the way thru but with the cd if you get off the rythme then I can hold a stedy throttle all the way thru. I've didn't like 300 from the 2nd day I had it and went to the diff lock with 300k before I had 500k. This set-up hooks up. I'm as strong off the line and it doesn't unload at all. but from 400 it's hardly noticable. In the center I have tried everything from 100-800, front 20-100 and rear 7-50. If you stay below 50 on your front I found that if you match it in the rear it hooks up better but don't go below 30k in the front.
    Hip Pocket Racing
    revo-world.com
  35. #435
    May 2006
    76
    So on a tight track with losts of turns and only one straight I wouldn't need to go as high as you?
    Is there something about that track (Johnny Cool Guy) that Slayden decided to use 100/500/50?
    Sorry, just trying to understand.
  36. #436
    Jan 2006
    okc
    2,210
    On a tight track you want it to come out of the turns strong so you might try 50-450-50 or 50-400-30. I really like my current set-up and would feel comfortable with it on any track. I did go to the standard ratio 15/40 for an inbetween feel.
    Hip Pocket Racing
    revo-world.com
  37. #437
    Registered User majestic's Avatar
    Mar 2006
    Plain'ol Texas
    553
  38. #438
    Aug 2002
    Dubai (U.A.E)
    30
    Truggy & REVO rim/tyre comparasion..?
    I have a REVO 2.5. All the guys at the track race truggies. Has someone put smaller diameter tyres on the REVO.? I feel with the smaller rims the truck will be more faster & more agile.
    The std REVO rims feel heavy & scrubs a lot of speed through the corners.
    I want to try & still use my REVO to keep with the truggies.HELP
    Any opinions on this idea...?
    T-Maxx RULES~!
  39. #439
    RC Turnbuckle Jr. 18t turbo's Avatar
    May 2004
    cherry hill, nj
    5,656
    Quote Originally Posted by Samaj
    I run bowtie mt's on 1/2 offset rims, they are awesome. They turn way better than 40 series, and maxx sized tires.
  40. #440
    Jan 2006
    okc
    2,210
    I put a set of panther lowpros on but for a big track that has any rough stuff I wouldn't recomend it. Theres a small indoor track that I use them on that is very smooth and just a few jumps and they hook-up great. Even on a small track with a 60-70 straight I had to gear it 16/34 and I still needed alittle more for that small of a straight. They do corner great though.
    Hip Pocket Racing
    revo-world.com
