Results 1 to 10 of 10
    Apr 2003
    Michigan
    365
    Charge Time Formula
    What is the formula to figure out charge times? I have two packs and currently use a timed charger that can trickle. But I want to make sure I do not overcharge them.
    "Jangified" Traxxas Rustler, Associated T3
    http://www.sccpropbusters.com/Redline.html
    May 2003
    Kitchener, Ontario
    359
    The above is true
    also if you charger does not have meter, and it has for example a max out of 4 amps or 4000 ma
    then it would take .5 hours to charge a 2000 mah pack (or 2 amp)
    I did not get this info from a RC person but an electronics instructor, if this does not hold true with sub-c someone please correct me because batteries are to expensive to burn.
    (the assumption is made that the pack is dischrged and the little charge it has is disippated into heat in the charging process)
    Rene
    Rides
    2.2 Crawlers, Clod Crawlers, T4 and a couple Pedes
    Jul 2003
    Edmond, OK
    1,596
    from what reniorbud said i would think 1 amp is 1000mah. am i right? because renoirbud said 4 amps is 4000mah and then 2000mah is 2 amps.
    -Brendan
    Jun 2003
    northeast ohio
    656
    so what ur saying is that 1500 mah battery pack would
    take 15 minutes to charge on a 4.5 amp rate charger??
    cause it would take 30 min on a 3 amp charge and 15 min
    in a 4.5 amp charge...(took me 10 min to calculate )
    but my charger charges a 1500 mah in 25-30 min....
    May 2003
    Kitchener, Ontario
    359
    no that is not what i meant
    a 4.5 amp charger puts out 4500 ma per hour there fore it would take 20 min to charge a 1500 mah pack
    (1500/4500*60)
    Even simpler EX. a 3000 mah pack takes an hour to charge on a three amp charger
    Rene
    Rides
    Jun 2003
    northeast ohio
    656
    20 min...? how'd i get 15?? o well i was close
    Apr 2003
    Michigan
    365
    I am trying to figure out how long to trickle charge my packs.....
    May 2003
    Kitchener, Ontario
    359
    Same math applies
    What charger are you using?
    What battery r you charging?
    Rides
    Jun 2003
    Bowling Green, Ohio
    2,100
    Your have to charge a Battery at capacity +40% to fully charge.
    ie: Charge a 1500 at 1.5a for 1 hour 24 mins, 3.0a for 42mins, 6.0a for 21mins, etc.
    To trickle charge a 1500, you have to charge at C/10 (150ma) for 14 hours.
    On most consumer rechargable batteries, the charging instructions on the battery will say charge at 1/10 of capacity for 14-16 hours.
    Apr 2003
    Michigan
    365
    Same math applies
    Currently have : http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXJC34
    Want to get: http://www2.towerhobbies.com/cgi-bi...p?&I=SG2933&P=K
    1500 Pack: http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXJA83
    1900 Pack: http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXDND9
