Skip to main content
Gift Cards
Cart
Wishlist
Subscribe
My Account
Find Dealer
Search Site
Receive Traxxas News
Email Address
I agree Traxxas may collect, use, and/or disclose the personal data I have provided to send marketing materials in compliance with the enhanced
Privacy Policy
GDPR
, and
CCPA
disclosures.
I agree to Traxxas’
Terms & Conditions
Privacy Policy
GDPR
, and
CCPA
disclosures regarding the storage, processing, and/or transmission of my personal data.
Model Showroom
Parts & Accessories
Batteries & Chargers
Community
Support
News
Apparel
Get $100 off when you buy two TRX-4MTs!
Use code TRX4MT at checkout.
Click Here>
Learn more >
Learn more >
1654: Wheel hubs, hex (2)/ stub axle pins (2)
$2.00
Buy Now
1654X: Wheel hubs, hex (blue-anodized, lightweight aluminum) (2)/ axle pins(2)
$9.00
Buy Now
1726: Antenna, tube (1)/ vinyl antenna cap (1)/ wire retainer (1)
$1.00
Buy Now
1747: Nuts, 4mm nylon locking (10)
$2.00
Buy Now
1747G: Nuts, aluminum, flanged, serrated (4mm) (green-anodized) (4)
$7.50
Buy Now
1747P: Nuts, 4mm flanged nylon locking (aluminum, pink anodized) (4)
$7.50
Buy Now
1747R: Nuts, aluminum, flanged, serrated (4mm) (blue-anodized) (4)
$7.50
Buy Now
1926: Antenna caps, vinyl (2)/ antenna spool
$2.00
Buy Now
1985: PTFE-coated Washers, 5x8x0.5mm (20) (use with ball bearings)
$2.00
Buy Now
2381X: Main diff with steel ring gear/ side cover plate/ screws (Bandit, Stampede®, Rustler®)
$6.00
Buy Now
2382: Planet gears (4)/ planet shafts (4)/ sun gears (2)/sun gear alignment shaft (1) all hardened steel
$6.00
Buy Now
2388X: Planetary gear differential with steel ring gear (complete) (fits Bandit, Stampede®, Rustler®)
$15.00
Buy Now
2423: Gear, 23-T pinion (48-pitch) (fits 3mm shaft)/ set screw
$3.00
Buy Now
2553: Screws, 3x15mm countersunk machine (6) (hex drive)
$2.50
Buy Now
2554: Screws, 3x6mm caphead machine (hex drive) (6)
$2.50
Buy Now
2555: Suspension arms, (rear) (2)
$10.00
Buy Now
2575: Screws, 3x6mm button-head machine (hex drive) (6)
$2.50
Buy Now
2576: Screws, 3x8mm button-head machine (hex drive) (6)
$2.50
Buy Now
2578: Screws, 3x12mm button-head machine (hex drive) (6)
$2.50
Buy Now
2579: Screws, 3x15mm button-head machine (hex drive) (6)
$2.50
Buy Now
2580: Screws, 3x20mm button-head machine (hex drive) (6)
$2.50
Buy Now
2582: Screws, 3x30mm button-head machine (hex drive) (6)
$2.50
Buy Now
2586: Screws, 3x15mm cap-head machine (hex drive) (6)
$2.50
Buy Now
2591: Screws, 3x23mm button-head machine (hex drive) (6)
$2.50
Buy Now
2592: Screws, 3x40mm button-head machine (hex drive) (6)
$3.00
Buy Now
2593: Screws, 3x14mm button-head machine (hex drive) (6)
$3.00
Buy Now
2743: Set (grub) screws, 3mm hardened (12)
$3.00
Buy Now
2754: Stub axle pins (4)
$1.00
Buy Now
3195: Top drive gear, steel (22-tooth)
$3.00
Buy Now
3236: Screws, 2.5x12mm cap-head machine (6)
$2.50
Buy Now
3351R: Motor, Velineon® 3500, brushless (assembled with 12-gauge wire and gold-plated bullet connectors)
$89.95
Buy Now
3355R: VXL-3s Waterproof Electronic Speed Control (brushless) (fwd/rev/brake)
$99.95
Buy Now
3640: Suspension screw pin set, steel (hex drive) (requires part # 2640 for a complete suspension pin set) (Rustler®, Stampede®, Bandit)
$4.50
Buy Now
3642X: Shoulder screws, Ultra Shocks (3x12 hex drive) (6)
$3.00
Buy Now
3644: Turnbuckles, camber link, 39mm (69mm center to center) (assembled with rod ends and hollow balls) (1 left, 1 right)
$7.00
Buy Now
3646: Screws, 3x15mm flat-head machine (hex drive) (6)
$2.50
Buy Now
3647: Nuts, 4mm flanged nylon locking (steel, serrated) (8)
$3.25
Buy Now
3652A: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (blue-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3652G: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (green-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3652P: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (pink-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3652X: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (red-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3677: Wheelie bar mount (1)/ hardware (Stampede®, Rustler®, Bandit series)
$4.00
Buy Now
3677A: Wheelie bar mount (1) / hardware (green)
$4.00
Buy Now
3677P: Wheelie bar mount (1) / hardware (pink)
$4.00
Buy Now
3677X: Wheelie bar mount (1) / hardware (blue)
$4.00
Buy Now
3691: Gearbox halves (L&R) (black) w/ idler gear shaft
$8.00
Buy Now
3691A: Gearbox halves (L&R) (grey) w/ idler gear shaft
$8.00
Buy Now
3696: Idler gear, steel (30-tooth)
$3.00
Buy Now
3737: Turnbuckle, aluminum (red-anodized), camber link, front, 39mm (1) (assembled w/rod ends)/hollow balls (2)(See part 3741X for complete camber link set)
$6.00
Buy Now
3737A: Turnbuckle, aluminum (blue-anodized), camber link, front, 39mm (1)(assembled w/rod ends)/hollow balls (2)(See part 3741A for complete camber link set)
$6.00
Buy Now
3752: Stub axle carriers (2) (requires 5x11x4mm bearings)
$3.00
Buy Now
3762A: Ultra Shocks (grey) (xx-long) (complete w/ spring pre-load spacers & springs) (rear) (2)
$18.00
Buy Now
3790: Gear adapter, fixed
$4.50
Buy Now
3792: Cover, gear/ rubber gear cover plug/ 3x6 RM (2)
$3.50
Buy Now
3793: Input shaft (slipper shaft) / spring pin
$3.00
Buy Now
3931: Screws, 3x8mm flat-head machine (hex drive) (6)
$2.50
Buy Now
3932: Screws, 3x6mm flat-head machine (hex drive) (6)
$2.50
Buy Now
3934: Body clips, heavy duty (12)
$3.00
Buy Now
3935: Body clip (mounting clip), angled, 90-degrees (10)
$3.00
Buy Now
3965: Screws, 2.5x8mm cap-head machine (6)
$2.50
Buy Now
4676: Spur gear, 76-tooth (48-pitch) (for models with Torque Control slipper clutch)
$3.00
Buy Now
4683: Spur gear, 83-tooth (48-pitch) (for models with Torque Control slipper clutch)
$3.00
Buy Now
4686: Spur gear, 86-tooth (48-pitch) (for models with Torque-Control slipper clutch)
$3.00
Buy Now
4690: Spur gear, 90-tooth (48-pitch) (for models with Torque-Control slipper clutch)
$3.00
Buy Now
4728: Gear, 28-T pinion (48-pitch) (fits 3mm shaft)/ set screw
$3.00
Buy Now
5116: Ball bearings, blue rubber sealed (5x11x4mm) (2)
$3.50
Buy Now
5525: Rod ends (12)/ hollow balls (12)
$9.00
Buy Now
5526: Antenna crimp nut, aluminum (blue-anodized)/ antenna nut tool
$4.00
Buy Now
5529: Shim set, 3x7x1mm (2), 3x6x0.5mm (4), 3x7x2mm (2)/ hollow balls, captured (4)
$3.50
Buy Now
5552X: Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (2)/ pin/ 4.0mm NL (1)/ 5.0mm NL (1))
$10.00
Notify Me
5556: Slipper pressure plate & hub (aluminum alloy)
$8.00
Buy Now
5624: Box, receiver (sealed)/ foam pad/ silicone grease/ 3x8mm BCS (2)/ 2.5x8mm CS (2)/ 3x6mm BCS (2)
$12.00
Buy Now
5625: Seal kit, receiver box (includes o-ring, seals, and silicone grease)
$4.00
Buy Now
5827: Hold down, battery/ hold down retainer/ battery post/ foam spacer/ angled body clip
$6.00
Buy Now
5827X: Hold down, battery/ hold down retainer/ battery post/ foam spacer/ angled body clip (allows for installation of taller, multi-cell batteries)
$6.00
Buy Now
5832: Chassis, low CG (black)
$19.00
Buy Now
5832A: Chassis, low CG (blue)
$19.00
Buy Now
5832G: Chassis, low CG (grey)
$19.00
Buy Now
5833: Nerf bars, low CG (black)
$4.00
Buy Now
5833A: Nerf bars, low CG (blue)
$4.00
Buy Now
5833G: Nerf bars, low CG (grey)
$4.00
Buy Now
5836: Bumper, rear/ bumper mount, rear (black)
$10.00
Buy Now
5836P: Bumper, rear/ bumper mount, rear (pink)
$10.00
Buy Now
5862: Big Bore shocks (hard-anodized & PTFE-coated T6 aluminum) (assembled with TiN shafts and springs) (front & rear) (4)
$59.95
Buy Now
5863: Tire & wheel assy, glued (SCT, black, orange beadlock wheels, SCT off-road racing tires, foam inserts) (2) (4WD f/r, 2WD rear) (TSM® rated)
$24.95
Buy Now
5864: Tire & wheel assy, glued (SCT, black, orange beadlock wheels, SCT off-road racing tires, foam inserts) (2) (2WD Front)
$24.95
Buy Now
5865: Tire & wheel assy, glued (SCT, chrome, green beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, foam inserts) (2) (2WD front only)
$24.95
Buy Now
5866: Wheels, SCT, chrome, green beadlock style, dual profile (2.2" outer 3.0" inner) (2) (2WD front only)
$10.95
Notify Me
5867: Tire & wheel assy, glued (SCT chrome, red beadlock style wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2)(4WD front/rear, 2WD rear only)
$24.95
Buy Now
5868: Wheels, SCT chrome, red beadlock style, dual profile (2.2" outer 3.0" inner) (2) (4WD front/rear, 2WD rear only)
$10.95
Buy Now
5868X: Wheels, SCT, black, orange beadlock style, dual profile (2.2" outer 3.0" inner) (4WD f/r, 2WD rear) (2)
$10.95
Buy Now
5869: Tire & wheel assy, glued (SCT chrome, red beadlock style wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5870X: Wheels, SCT, black, orange beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$10.95
Buy Now
5871: Tires, off-road racing, SCT dual profile 4.3x1.7- 2.2/3.0" (2)/ foam inserts (2)
$18.95
Buy Now
5871R: Tires, Ultra soft, S1 compound for off-road racing, SCT dual profile 4.3x1.7- 2.2/3.0" (2)/ foam inserts (2)
$18.95
Buy Now
5872: Wheels, SCT satin chrome, beadlock style, dual profile (2.2" outer 3.0" inner) (2) (Rear)
$7.95
Buy Now
5872X: Wheels, SCT satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (2) (4WD front/rear, 2WD rear only)
$10.95
Buy Now
5873: Tires & wheels, assembled, glued (SCT, satin chrome wheels, beadlock type (dual profile 2.2" outer 3.0" inner), SCT off-road tires, foam inserts) (2) (Rear) (TSM® rated)
$21.95
Buy Now
5873A: Tires & wheels, assembled, glued (SCT, satin chrome wheels, red beadlock, (dual profile 2.2" outer 3.0" inner), SCT off-road tires, foam inserts) (2) (Rear)
$24.95
Buy Now
5873R: Tires & wheels, assembled, glued (SCT, satin chrome, red beadlock wheels, ultra soft S1 compound off-road racing tires, foam inserts) (2) (2WD Rear, 4WD F/R)
$24.95
Buy Now
5873X: Tire & wheel assy, glued (SCTsatin chrome, black beadlock style wheels, SCT off-road racing tires, foam inserts) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
5874: Wheels, SCT satin chrome, beadlock style, dual profile (2.2" outer 3.0" inner) (2) (Front)
$7.95
Buy Now
5874A: Wheels, SCT satin chrome, red beadlock style, dual profile (2.2" outer 3.0" inner) (Front) (2)
$10.95
Notify Me
5874X: Wheels, SCT satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (2) (2WD front only)
$10.95
Buy Now
5875: Tires & wheels, assembled, glued (SCT, satin chrome wheels, beadlock type (dual profile 2.2" outer 3.0" inner), SCT off-road tires, foam inserts) (2) (Front)
$22.95
Buy Now
5875X: Tire & wheel assy, glued (SCT satin chrome, black beadlock style wheels, SCT off-road racing tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5876: Wheels, SCT Split-Spoke, satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$8.95
Buy Now
5877: Tire & wheel assy, glued (SCT Split-Spoke, satin, black beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, foam inserts) (2) (2WD Front)
$23.95
Buy Now
5877A: Tire & wheel assy, glued (SCT Split-Spoke, chrome red beadlock wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2) (2WD Front)
$24.95
Buy Now
5877R: Tire & wheel assy, glued (S1 compound) (SCT Split-Spoke, chrome red beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2) (2WD front)
$24.95
Buy Now
5878: Tire & wheel assy, glued (SCT satin chrome, black beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, insert) (2)(4WD front/rear, 2WD rear only)
$24.95
Buy Now
5880X: Tire & wheel assy, glued (SCT satin chrome, beadlock style wheels, Kumho tires, foam inserts) (2) (4WD front/rear, 2WD rear only)
$22.95
Buy Now
5881X: Tire & wheel assy, glued (SCT satin chrome, beadlock style wheels, Kumho tires, foam inserts) (2) (2WD front only)
$22.95
Buy Now
5882: Tire & wheel assy, glued (SCT Split-Spoke satin chrome, black beadlock style wheels, Kumho tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5882R: Tire & wheel assy, glued (S1 compound) (SCT Split-Spoke satin chrome, black beadlock style wheels, Kumho tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5883: Tire & wheel assy, glued (SCT Split-Spoke, black, satin chrome beadlock wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
5884: Wheels, SCT Split-Spoke, black, satin chrome beadlock style, dual profile (2.2" outer 3.0" inner) (4WD f/r, 2WD rear) (2)
$10.95
Buy Now
5884A: Wheels, SCT Split-Spoke, black, blue beadlock style, dual profile (2.2" outer 3.0" inner) (4WD f/r, 2WD rear) (2)
$10.95
Order Now
Ships Mid March
5885: Tire & wheel assy, glued (SCT Split-Spoke, black, satin chrome beadlock wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2) (2WD Front)
$24.95
Buy Now
5886: Wheels, SCT Split-Spoke, black, satin chrome beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$10.95
Buy Now
5886A: Wheels, SCT split-spoke, black, blue beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$10.95
Buy Now
6533: Receiver, micro, TQi 2.4GHz with telemetry & TSM® (5-channel)
$39.95
Buy Now
6580: Sound output module, On-Board Audio system (1)
$35.00
Buy Now
6581: Double-sided adhesive, sound output module (4)
$2.00
Buy Now
6585: Mounts, sound output module, Slash (front & rear)
$10.00
Notify Me
6850X: Half shafts, heavy duty (external splined (2)/ internal splined (2))/ metal u-joints (4)
$8.00
Buy Now
6852R: Driveshafts, rear, steel-spline constant-velocity (complete assembly) (2)
$69.95
Buy Now
6853X: Stub axles, rear, heavy duty (2)/pins (2)
$6.00
Buy Now
6870: Tires, Kumho (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6870R: Tires, Kumho, ultra-soft (S1 off-road racing compound) (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6871: Tires, BFGoodrich® Mud-Terrain™ T/A® KM2 (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6871R: Tires, BFGoodrich® Mud-Terrain™ T/A® KM2 , ultra-soft (S1 off-road racing compound) (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6872: Wheels, SCT Split-Spoke, satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (4WD front/rear, 2WD rear only) (2)
$7.95
Buy Now
6872A: Wheels, SCT Split-Spoke, chrome, red beadlock style, dual profile (2.2" outer 3.0" inner) (4WD front/rear, 2WD rear) (2)
$10.95
Buy Now
6872X: Wheels, SCT Split-Spoke, chrome, green beadlock style, dual profile (2.2" outer 3.0" inner) (4WD front/rear, 2WD rear) (2)
$10.95
Notify Me
6873: Tires & wheels, assembled, glued (SCT Split-Spoke satin chrome, black beadlock style wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, foam inserts) (2) (4WD f/r, 2WD rear) (TSM® rated)
$21.95
Buy Now
6873A: Tire & wheel assy, glued (SCT Split-Spoke chrome, red beadlock style wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
6873R: Tire & wheel assy, glued (S1 compound) (SCT SS, chrome red beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
6873X: Tire & wheel assy, glued (S1 compound) (SCT SS, satin chrome black beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
6874: Tire & wheel assy, glued (SCT Split-Spoke satin chrome, black beadlock style wheels, Kumho tires, foam inserts) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
6874R: Tire & wheel assy, glued (S1 compound) (SCT Split-Spoke satin chrome, black beadlock wheel, Kumho tire, insert) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
6875: Wheels, SCT, chrome, green beadlock style, dual profile (2.2" outer 3.0" inner) (2) c
$10.95
Notify Me
6876: Tire & wheel assy, glued (SCT, chrome, green beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, foam inserts) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
6877: Cover, gear/ motor wire hold-down clip
$4.50
Buy Now
8361: Shock caps (black) (4) (assembled with hollow balls)
$5.00
Buy Now
Slash VXL (58076-21) Chassis Assembly Exploded View
Print
View PDF
