Skip to main content
Gift Cards
Cart
Wishlist
Subscribe
My Account
Find Dealer
Search Site
Receive Traxxas News
Email Address
I agree Traxxas may collect, use, and/or disclose the personal data I have provided to send marketing materials in compliance with the enhanced
Privacy Policy
GDPR
, and
CCPA
disclosures.
I agree to Traxxas’
Terms & Conditions
Privacy Policy
GDPR
, and
CCPA
disclosures regarding the storage, processing, and/or transmission of my personal data.
Model Showroom
Parts & Accessories
Batteries & Chargers
Community
Support
News
On Sale
Keep the Fun Going! Save 20% on aluminum, bodies, and wheels & tires.
Use code FUN2025.
Click Here >
Learn more >
Learn more >
1654: Wheel hubs, hex (2)/ stub axle pins (2)
$2.00
Buy Now
1654X: Wheel hubs, hex (blue-anodized, lightweight aluminum) (2)/ axle pins(2)
$9.00
Buy Now
1747R: Nuts, aluminum, flanged, serrated (4mm) (blue-anodized) (4)
$7.50
Buy Now
1765: Silicone diaphragms (4)
$2.00
Buy Now
1942: Rod ends (16 long & 4 short)/ hollow ball connectors (18)/ ball screws (2)
$7.00
Buy Now
1952: Carriers, stub axle (rear) (2)
$3.00
Buy Now
1952A: Carriers, stub axle (red-anodized 6061-T6 aluminum) (rear) (left & right)/ 3x32mm hinge pins (2)/ e-clips (6)/ hardware
$25.95
Buy Now
1952X: Carriers, stub axle (blue-anodized 6061-T6 aluminum) (rear) (left & right)/ 3x32mm hinge pins (2)/ e-clips (6)/ hardware
$25.95
Buy Now
1985: PTFE-coated Washers, 5x8x0.5mm (20) (use with ball bearings)
$2.00
Buy Now
2362: Shock rebuild kit (for 2 shocks)
$2.50
Buy Now
2550: Screws, 3x8mm countersunk machine (6) (hex drive)
$2.50
Buy Now
2551: Screws, 3x10mm countersunk machine (6) (hex drive)
$2.50
Buy Now
2552: Screws, 3x12mm countersunk machine (6) (hex drive)
$2.50
Buy Now
2554: Screws, 3x6mm caphead machine (hex drive) (6)
$2.50
Buy Now
2575: Screws, 3x6mm button-head machine (hex drive) (6)
$2.50
Buy Now
2576: Screws, 3x8mm button-head machine (hex drive) (6)
$2.50
Buy Now
2577: Screws, 3x10mm button-head machine (hex drive) (6)
$2.50
Buy Now
2578: Screws, 3x12mm button-head machine (hex drive) (6)
$2.50
Buy Now
2579: Screws, 3x15mm button-head machine (hex drive) (6)
$2.50
Buy Now
2580: Screws, 3x20mm button-head machine (hex drive) (6)
$2.50
Buy Now
2656: Shock shafts, steel, chrome finish (xx-long) (2)
$3.00
Buy Now
2656T: Shock shafts, hardened steel, titanium nitride coated (xx-long) (2)
$10.00
Buy Now
2742X: Rod ends, short (6)/ hollow balls (6)
$4.00
Buy Now
2743: Set (grub) screws, 3mm hardened (12)
$3.00
Buy Now
2746: Washers, 3x6mm metal (12)
$1.50
Buy Now
2754: Stub axle pins (4)
$1.00
Buy Now
3351R: Motor, Velineon® 3500, brushless (assembled with 12-gauge wire and gold-plated bullet connectors)
$99.95
Buy Now
3642X: Shoulder screws, Ultra Shocks (3x12 hex drive) (6)
$3.00
Buy Now
3644: Turnbuckles, camber link, 39mm (69mm center to center) (assembled with rod ends and hollow balls) (1 left, 1 right)
$7.00
Buy Now
3647: Nuts, 4mm flanged nylon locking (steel, serrated) (8)
$3.25
Buy Now
3655X: Suspension arms, left & right
$10.00
Buy Now
3766A: Body, Ultra Shock (XXL) (grey) (2)
$3.00
Buy Now
3767: Shock caps (2)/ shock bottoms (2)
$3.00
Buy Now
3767A: Shock caps, aluminum (blue-anodized) (4) (fits all Ultra Shocks)
$14.00
Buy Now
3767X: Shock caps, aluminum (red-anodized) (4) (fits all Ultra Shocks)
$14.00
Buy Now
3768: Spring retainers, upper & lower (2)/ piston head set (2-hole (2)/ 3-hole (2))
$3.00
Buy Now
3769: Spring pre-load spacers: 1mm (4)/ 2mm (2)/ 4mm (2)/ 8mm (2)
$4.00
Buy Now
3931: Screws, 3x8mm flat-head machine (hex drive) (6)
$2.50
Buy Now
3932: Screws, 3x6mm flat-head machine (hex drive) (6)
$2.50
Buy Now
3936: Screws, 4x10mm button-head machine (hex drive) (6)
$2.50
Buy Now
3937: Screws, 4x12mm button-head machine (hex drive) (6)
$2.50
Buy Now
3938: Screws, 4x14mm button-head machine (hex drive) (6)
$2.50
Buy Now
3956: Spur gear, 54-tooth (0.8 metric pitch, compatible with 32-pitch)
$3.00
Buy Now
3956R: Spur gear, 54-tooth (0.8 metric pitch, compatible with 32-pitch) (for center differential)
$3.00
Buy Now
3965: Screws, 2.5x8mm cap-head machine (6)
$2.50
Buy Now
5116: Ball bearings, blue rubber sealed (5x11x4mm) (2)
$3.50
Buy Now
5118: Ball bearings, blue rubber sealed (8x16x5mm) (2)
$6.00
Buy Now
5119: Ball bearings, blue rubber sealed (10x15x4mm) (2)
$7.00
Buy Now
5119A: Ball bearings, black rubber sealed (10x15x4mm) (2)
$7.00
Buy Now
5120: Ball bearings, blue rubber sealed (12x18x4mm) (2)
$8.00
Buy Now
5142: Screws, 3x15mm caphead machine (hex drive) (with split and flat washers) (6)
$2.75
Buy Now
5351: Slipper pressure plate and hub (alloy)
$8.00
Buy Now
5352X: Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (1)/ 2x9.8mm pin/ 5x8mm MW/ 5.0mm NL (1)/ 4.0mm NL (1))
$7.50
Notify Me
5381: Carrier, differential/ x-ring gaskets (2)/ ring gear gasket/ 6x10x0.5 TW
$4.25
Buy Now
5525: Rod ends (12)/ hollow balls (12)
$9.00
Buy Now
5552X: Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (2)/ pin/ 4.0mm NL (1)/ 5.0mm NL (1))
$10.00
Notify Me
5556: Slipper pressure plate & hub (aluminum alloy)
$8.00
Buy Now
5863: Tire & wheel assy, glued (SCT, black, orange beadlock wheels, SCT off-road racing tires, foam inserts) (2) (4WD f/r, 2WD rear) (TSM® rated)
$24.95
Buy Now
5864: Tire & wheel assy, glued (SCT, black, orange beadlock wheels, SCT off-road racing tires, foam inserts) (2) (2WD Front)
$24.95
Buy Now
5865: Tire & wheel assy, glued (SCT, chrome, green beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, foam inserts) (2) (2WD front only)
$24.95
Buy Now
5866: Wheels, SCT, chrome, green beadlock style, dual profile (2.2" outer 3.0" inner) (2) (2WD front only)
$10.95
Notify Me
5867: Tire & wheel assy, glued (SCT chrome, red beadlock style wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2)(4WD front/rear, 2WD rear only)
$24.95
Buy Now
5868: Wheels, SCT chrome, red beadlock style, dual profile (2.2" outer 3.0" inner) (2) (4WD front/rear, 2WD rear only)
$10.95
Buy Now
5868X: Wheels, SCT, black, orange beadlock style, dual profile (2.2" outer 3.0" inner) (4WD f/r, 2WD rear) (2)
$10.95
Buy Now
5869: Tire & wheel assy, glued (SCT chrome, red beadlock style wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5870X: Wheels, SCT, black, orange beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$10.95
Buy Now
5871: Tires, off-road racing, SCT dual profile 4.3x1.7- 2.2/3.0" (2)/ foam inserts (2)
$18.95
Buy Now
5871R: Tires, Ultra soft, S1 compound for off-road racing, SCT dual profile 4.3x1.7- 2.2/3.0" (2)/ foam inserts (2)
$18.95
Buy Now
5872: Wheels, SCT satin chrome, beadlock style, dual profile (2.2" outer 3.0" inner) (2) (Rear)
$7.95
Buy Now
5872X: Wheels, SCT satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (2) (4WD front/rear, 2WD rear only)
$10.95
Buy Now
5873: Tires & wheels, assembled, glued (SCT, satin chrome wheels, beadlock type (dual profile 2.2" outer 3.0" inner), SCT off-road tires, foam inserts) (2) (Rear) (TSM® rated)
$21.95
Buy Now
5873A: Tires & wheels, assembled, glued (SCT, satin chrome wheels, red beadlock, (dual profile 2.2" outer 3.0" inner), SCT off-road tires, foam inserts) (2) (Rear)
$24.95
Buy Now
5873R: Tires & wheels, assembled, glued (SCT, satin chrome, red beadlock wheels, ultra soft S1 compound off-road racing tires, foam inserts) (2) (2WD Rear, 4WD F/R)
$24.95
Buy Now
5873X: Tire & wheel assy, glued (SCTsatin chrome, black beadlock style wheels, SCT off-road racing tires, foam inserts) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
5874: Wheels, SCT satin chrome, beadlock style, dual profile (2.2" outer 3.0" inner) (2) (Front)
$7.95
Buy Now
5874A: Wheels, SCT satin chrome, red beadlock style, dual profile (2.2" outer 3.0" inner) (Front) (2)
$10.95
Notify Me
5874X: Wheels, SCT satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (2) (2WD front only)
$10.95
Buy Now
5875: Tires & wheels, assembled, glued (SCT, satin chrome wheels, beadlock type (dual profile 2.2" outer 3.0" inner), SCT off-road tires, foam inserts) (2) (Front)
$22.95
Buy Now
5875X: Tire & wheel assy, glued (SCT satin chrome, black beadlock style wheels, SCT off-road racing tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5876: Wheels, SCT Split-Spoke, satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$8.95
Buy Now
5877: Tire & wheel assy, glued (SCT Split-Spoke, satin, black beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, foam inserts) (2) (2WD Front)
$23.95
Buy Now
5877A: Tire & wheel assy, glued (SCT Split-Spoke, chrome red beadlock wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2) (2WD Front)
$24.95
Buy Now
5877R: Tire & wheel assy, glued (S1 compound) (SCT Split-Spoke, chrome red beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2) (2WD front)
$24.95
Buy Now
5878: Tire & wheel assy, glued (SCT satin chrome, black beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, insert) (2)(4WD front/rear, 2WD rear only)
$24.95
Buy Now
5880X: Tire & wheel assy, glued (SCT satin chrome, beadlock style wheels, Kumho tires, foam inserts) (2) (4WD front/rear, 2WD rear only)
$22.95
Buy Now
5881X: Tire & wheel assy, glued (SCT satin chrome, beadlock style wheels, Kumho tires, foam inserts) (2) (2WD front only)
$22.95
Buy Now
5882: Tire & wheel assy, glued (SCT Split-Spoke satin chrome, black beadlock style wheels, Kumho tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5882R: Tire & wheel assy, glued (S1 compound) (SCT Split-Spoke satin chrome, black beadlock style wheels, Kumho tires, foam inserts) (2) (2WD front)
$24.95
Buy Now
5883: Tire & wheel assy, glued (SCT Split-Spoke, black, satin chrome beadlock wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
5884: Wheels, SCT Split-Spoke, black, satin chrome beadlock style, dual profile (2.2" outer 3.0" inner) (4WD f/r, 2WD rear) (2)
$10.95
Buy Now
5884A: Wheels, SCT Split-Spoke, black, blue beadlock style, dual profile (2.2" outer 3.0" inner) (4WD f/r, 2WD rear) (2)
$10.95
Buy Now
5885: Tire & wheel assy, glued (SCT Split-Spoke, black, satin chrome beadlock wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, inserts) (2) (2WD Front)
$24.95
Buy Now
5886: Wheels, SCT Split-Spoke, black, satin chrome beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$10.95
Buy Now
5886A: Wheels, SCT split-spoke, black, blue beadlock style, dual profile (2.2" outer 3.0" inner) (2WD front) (2)
$10.95
Buy Now
6580: Sound output module, On-Board Audio system (1)
$35.00
Buy Now
6581: Double-sided adhesive, sound output module (4)
$2.00
Buy Now
6585: Mounts, sound output module, Slash (front & rear)
$10.00
Notify Me
6815R: Body mount (1)/ body mount post (2)/ body post extensions (2) (front or rear)
$4.00
Buy Now
6823: Bulkhead tie bars, front & rear, aluminum (blue-anodized)
$7.00
Buy Now
6828X: Differential output yokes, heavy duty (2)/ screw pin (2)
$4.00
Buy Now
6834: Suspension pin set, complete (front and rear)
$4.00
Buy Now
6838: Shock tower, rear
$6.00
Buy Now
6838X: Shock tower, rear, 7075-T6 aluminum (blue-anodized) (1)/ body mount bracket (1)
$25.95
Buy Now
6842: Spur gear, 50-tooth (0.8 metric pitch, compatible with 32-pitch)
$3.00
Buy Now
6842R: Spur gear, 50-tooth (0.8 metric pitch, compatible with 32-pitch) (for Slash 4x4 center differential)
$3.00
Buy Now
6843: Spur gear, 52-tooth (0.8 metric pitch, compatible with 32-pitch)
$3.00
Buy Now
6843R: Spur gear, 52-tooth (0.8 metric pitch, compatible with 32-pitch) (for Slash 4x4 center differential)
$3.00
Buy Now
6850X: Half shafts, heavy duty (external splined (2)/ internal splined (2))/ metal u-joints (4)
$8.00
Buy Now
6851X: Driveshaft assembly, front, heavy duty (1) (left or right) (fully assembled, ready to install)/ screw pin (1)
$10.00
Buy Now
6852R: Driveshafts, rear, steel-spline constant-velocity (complete assembly) (2)
$69.95
Buy Now
6852X: Driveshaft assembly, rear, heavy duty (1) (left or right) (fully assembled, ready to install)/ screw pin (1)
$10.00
Buy Now
6853X: Stub axles, rear, heavy duty (2)/pins (2)
$6.00
Buy Now
6854X: Stub axles, front, heavy duty (2)/ yokes (2)/ pins (4)
$8.00
Buy Now
6855: Driveshaft, center, 6061-T6 aluminum (blue-anodized) (214mm)
$10.00
Buy Now
6858: Springs, rear (white) (progressive rate) (2)
$6.50
Buy Now
6860A: Motor mount (assembled with 3x6 flat-head machine screw)/ 3.0mm NL (1)
$4.00
Buy Now
6870: Tires, Kumho (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6870R: Tires, Kumho, ultra-soft (S1 off-road racing compound) (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6871: Tires, BFGoodrich® Mud-Terrain™ T/A® KM2 (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6871R: Tires, BFGoodrich® Mud-Terrain™ T/A® KM2 , ultra-soft (S1 off-road racing compound) (dual profile 4.3x1.7- 2.2/3.0") (2)/ foam inserts (2)
$18.95
Buy Now
6872: Wheels, SCT Split-Spoke, satin chrome, black beadlock style, dual profile (2.2" outer 3.0" inner) (4WD front/rear, 2WD rear only) (2)
$7.95
Buy Now
6872A: Wheels, SCT Split-Spoke, chrome, red beadlock style, dual profile (2.2" outer 3.0" inner) (4WD front/rear, 2WD rear) (2)
$10.95
Buy Now
6872X: Wheels, SCT Split-Spoke, chrome, green beadlock style, dual profile (2.2" outer 3.0" inner) (4WD front/rear, 2WD rear) (2)
$10.95
Buy Now
6873: Tires & wheels, assembled, glued (SCT Split-Spoke satin chrome, black beadlock style wheels, BFGoodrich® Mud-Terrain™ T/A® KM2 tires, foam inserts) (2) (4WD f/r, 2WD rear) (TSM® rated)
$21.95
Buy Now
6873A: Tire & wheel assy, glued (SCT Split-Spoke chrome, red beadlock style wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
6873R: Tire & wheel assy, glued (S1 compound) (SCT SS, chrome red beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
6873X: Tire & wheel assy, glued (S1 compound) (SCT SS, satin chrome black beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, inserts) (2) (4WD f/r, 2WD rear)
$24.95
Buy Now
6874: Tire & wheel assy, glued (SCT Split-Spoke satin chrome, black beadlock style wheels, Kumho tires, foam inserts) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
6874R: Tire & wheel assy, glued (S1 compound) (SCT Split-Spoke satin chrome, black beadlock wheel, Kumho tire, insert) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
6875: Wheels, SCT, chrome, green beadlock style, dual profile (2.2" outer 3.0" inner) (2) c
$10.95
Notify Me
6876: Tire & wheel assy, glued (SCT, chrome, green beadlock wheel, BFGoodrich® Mud-Terrain™ T/A® KM2 tire, foam inserts) (2) (4WD front/rear, 2WD rear only)
$24.95
Buy Now
6879: Ring gear, differential/ pinion gear, differential (rear)
$15.00
Buy Now
6880: Housings, differential, rear
$4.00
Buy Now
6883: Gear set, center differential (output gears (2)/ spider gears (2)/ spider gear shaft)
$15.00
Buy Now
6884: Housing, center differential/ x-ring gaskets (2)/ ring gear gasket/ bushings (2)/ 5x10x0.5 TW (2)/ CCS 2.5x8 (4)
$5.00
Buy Now
6888: Drive hub, center, rear (1)/ 4x3 GS (1)
$5.00
Buy Now
6893: Input shaft (slipper shaft)/ bearing adapter (1)/ pin (1)
$6.50
Buy Now
6893X: Bearing adapter, 6061-T6 aluminum (blue-anodized) (1)/10x15x4mm ball bearing (black rubber sealed) (1) (for slipper shaft)
$5.00
Buy Now
7422: Chassis
$20.00
Buy Now
7429: Bulkhead, rear
$6.00
Buy Now
7477: Cover, gear/ wire retainer
$3.00
Buy Now
7490: Plate, motor
$7.00
Buy Now
Slash 4X4 (68086-21) Rear Assembly Exploded View
Print
View PDF
