Skip to main content
Gift Cards
Cart
Wishlist
Subscribe
My Account
Find Dealer
Search Site
Receive Traxxas News
Email Address
I agree Traxxas may collect, use, and/or disclose the personal data I have provided to send marketing materials in compliance with the enhanced
Privacy Policy
GDPR
, and
CCPA
disclosures.
I agree to Traxxas’
Terms & Conditions
Privacy Policy
GDPR
, and
CCPA
disclosures regarding the storage, processing, and/or transmission of my personal data.
Model Showroom
Parts & Accessories
Batteries & Chargers
Community
Support
News
On Sale
Keep the Fun Going! Save 20% on aluminum, bodies, and wheels & tires.
Use code FUN2025.
Click Here >
Learn more >
Learn more >
1747: Nuts, 4mm nylon locking (10)
$2.00
Buy Now
1951: Half shafts, long truck (external-splined (2) & internal-splined (2)/ metal U-joints (4)
$6.00
Buy Now
1951R: Driveshafts, rear, steel-spline constant-velocity (complete assembly) (2) (fits 2WD Rustler®/Stampede®)
$69.95
Buy Now
1953: Half shaft pro-pack (internal-splined (6)/ external-splined (6) (plastic shafts only)
$10.00
Buy Now
1985: PTFE-coated Washers, 5x8x0.5mm (20) (use with ball bearings)
$2.00
Buy Now
2381X: Main diff with steel ring gear/ side cover plate/ screws (Bandit, Stampede®, Rustler®)
$6.00
Buy Now
2382: Planet gears (4)/ planet shafts (4)/ sun gears (2)/sun gear alignment shaft (1) all hardened steel
$6.00
Buy Now
2388X: Planetary gear differential with steel ring gear (complete) (fits Bandit, Stampede®, Rustler®)
$15.00
Buy Now
2416: Gear, 16-T pinion (48-pitch) / set screw
$3.50
Buy Now
2419: Gear, 19-T pinion (48-pitch) / set screw
$3.00
Buy Now
2423: Gear, 23-T pinion (48-pitch) (fits 3mm shaft)/ set screw
$3.00
Buy Now
2427: Gear, 14-T pinion (48-pitch) (fits 3mm shaft)/ set screw
$3.00
Buy Now
2554: Screws, 3x6mm caphead machine (hex drive) (6)
$2.50
Buy Now
2558: Screws, 3x6mm roundhead machine (6)
$1.50
Buy Now
2566: Screws, 3x20mm roundhead machine (6)
$1.50
Buy Now
2567: Screws, 3x23mm roundhead machine (6)
$1.50
Buy Now
2572: Screws, 3x30mm roundhead machine (6)
$1.50
Buy Now
2743: Set (grub) screws, 3mm hardened (12)
$3.00
Buy Now
2754: Stub axle pins (4)
$1.00
Buy Now
3185X: Screws, 3x8mm washerhead machine (large head for motor mount) (6)
$1.50
Buy Now
3195: Top drive gear, steel (22-tooth)
$3.00
Buy Now
3691: Gearbox halves (L&R) (black) w/ idler gear shaft
$8.00
Buy Now
3691A: Gearbox halves (L&R) (grey) w/ idler gear shaft
$8.00
Buy Now
3696: Idler gear, steel (30-tooth)
$3.00
Buy Now
3785: Motor, Titan® 12T (12-Turn, 550 size)
$25.95
Buy Now
3790: Gear adapter, fixed
$4.50
Buy Now
3792: Cover, gear/ rubber gear cover plug/ 3x6 RM (2)
$3.50
Buy Now
3793: Input shaft (slipper shaft) / spring pin
$3.00
Buy Now
4628: Differential output yokes (2)/ 3x5mm countersunk screws (2)/ 3mm set (set) screws (4)
$4.00
Buy Now
4628X: Differential output yokes, hardened steel (w/ U-joints) (2)
$19.50
Buy Now
4676: Spur gear, 76-tooth (48-pitch) (for models with Torque Control slipper clutch)
$3.00
Buy Now
4683: Spur gear, 83-tooth (48-pitch) (for models with Torque Control slipper clutch)
$3.00
Buy Now
4686: Spur gear, 86-tooth (48-pitch) (for models with Torque-Control slipper clutch)
$3.00
Buy Now
4690: Spur gear, 90-tooth (48-pitch) (for models with Torque-Control slipper clutch)
$3.00
Buy Now
5116: Ball bearings, blue rubber sealed (5x11x4mm) (2)
$3.50
Buy Now
5552X: Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (2)/ pin/ 4.0mm NL (1)/ 5.0mm NL (1))
$10.00
Notify Me
5556: Slipper pressure plate & hub (aluminum alloy)
$8.00
Buy Now
Skully (36064-1) Transmission Assembly Exploded View
Print
View PDF
