Skip to main content
Gift Cards
Cart
Wishlist
Subscribe
My Account
Find Dealer
Search Site
Receive Traxxas News
Email Address
I agree Traxxas may collect, use, and/or disclose the personal data I have provided to send marketing materials in compliance with the enhanced
Privacy Policy
GDPR
, and
CCPA
disclosures.
I agree to Traxxas’
Terms & Conditions
Privacy Policy
GDPR
, and
CCPA
disclosures regarding the storage, processing, and/or transmission of my personal data.
Model Showroom
Parts & Accessories
Batteries & Chargers
Community
Support
News
On Sale
Keep the Fun Going! Save 20% on aluminum, bodies, and wheels & tires.
Use code FUN2025.
Click Here >
Learn more >
Learn more >
1654: Wheel hubs, hex (2)/ stub axle pins (2)
$2.00
Buy Now
1675: Bushings, self-lubricating (5x11x4mm) (14)
$5.00
Buy Now
1747: Nuts, 4mm nylon locking (10)
$2.00
Buy Now
1747G: Nuts, aluminum, flanged, serrated (4mm) (green-anodized) (4)
$7.50
Buy Now
1747P: Nuts, 4mm flanged nylon locking (aluminum, pink anodized) (4)
$7.50
Buy Now
1747R: Nuts, aluminum, flanged, serrated (4mm) (blue-anodized) (4)
$7.50
Buy Now
1951: Half shafts, long truck (external-splined (2) & internal-splined (2)/ metal U-joints (4)
$6.00
Buy Now
1951R: Driveshafts, rear, steel-spline constant-velocity (complete assembly) (2) (fits 2WD Rustler®/Stampede®)
$69.95
Buy Now
1953: Half shaft pro-pack (internal-splined (6)/ external-splined (6) (plastic shafts only)
$10.00
Buy Now
1985: PTFE-coated Washers, 5x8x0.5mm (20) (use with ball bearings)
$2.00
Buy Now
2381X: Main diff with steel ring gear/ side cover plate/ screws (Bandit, Stampede®, Rustler®)
$6.00
Buy Now
2382: Planet gears (4)/ planet shafts (4)/ sun gears (2)/sun gear alignment shaft (1) all hardened steel
$6.00
Buy Now
2388X: Planetary gear differential with steel ring gear (complete) (fits Bandit, Stampede®, Rustler®)
$15.00
Buy Now
2416: Gear, 16-T pinion (48-pitch) / set screw
$3.50
Buy Now
2419: Gear, 19-T pinion (48-pitch) / set screw
$3.00
Buy Now
2423: Gear, 23-T pinion (48-pitch) (fits 3mm shaft)/ set screw
$3.00
Buy Now
2427: Gear, 14-T pinion (48-pitch) (fits 3mm shaft)/ set screw
$3.00
Buy Now
2548: Screws, 4x12mm countersunk machine (100-degree) (6)
$1.50
Buy Now
2554: Screws, 3x6mm caphead machine (hex drive) (6)
$2.50
Buy Now
2558: Screws, 3x6mm roundhead machine (6)
$1.50
Buy Now
2566: Screws, 3x20mm roundhead machine (6)
$1.50
Buy Now
2567: Screws, 3x23mm roundhead machine (6)
$1.50
Buy Now
2572: Screws, 3x30mm roundhead machine (6)
$1.50
Buy Now
2593: Screws, 3x14mm button-head machine (hex drive) (6)
$3.00
Buy Now
2648: Screws, 3x12mm countersunk self-tapping (6)
$1.50
Buy Now
2676: Screws, 3x12mm roundhead self-tapping (6)
$1.50
Buy Now
2743: Set (grub) screws, 3mm hardened (12)
$3.00
Buy Now
2746: Washers, 3x6mm metal (12)
$1.50
Buy Now
2753X: Stub axles, rear (2)
$5.00
Buy Now
2754: Stub axle pins (4)
$1.00
Buy Now
3185X: Screws, 3x8mm washerhead machine (large head for motor mount) (6)
$1.50
Buy Now
3186: Screws, 3x12mm washerhead machine (6)
$1.50
Buy Now
3195: Top drive gear, steel (22-tooth)
$3.00
Buy Now
3619: Body mounts, front & rear/ body mount posts, front & rear (adjustable)/ 2.5x18mm screw pins (4)
$9.00
Buy Now
3641: Camber link set (plastic/ non-adjustable) (front & rear) (black)
$3.00
Buy Now
3641A: Camber link set (plastic / non-adjustable ) ( front & rear) (gray)
$3.00
Buy Now
3642: Attachment screws, shock (3x12mm shoulder screws) (6)
$3.00
Buy Now
3647: Nuts, 4mm flanged nylon locking (steel, serrated) (8)
$3.25
Buy Now
3652A: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (blue-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3652G: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (green-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3652P: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (pink-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3652X: Stub axle carriers, Rustler®/Stampede®/Bandit (2), 6061-T6 aluminum (red-anodized)/ 5x11mm ball bearings (4)
$29.95
Buy Now
3655X: Suspension arms, left & right
$10.00
Buy Now
3663: Tires & wheels, assembled, glued (satin chrome wheels, Terra Groove dual profile tires, foam inserts) (electric rear) (2)
$29.95
Buy Now
3667: Tires, Terra Groove (dual profile 5.3"x2.7"- 2.0") (2)/ foam inserts (2)
$19.95
Notify Me
3668: Tires & wheels, assembled, glued (2.8") (All-Star chrome wheels, Talon tires, foam inserts) (electric rear) (2)
$25.95
Buy Now
3668A: Tires & wheels, assembled, glued (2.8") (All-Star black chrome wheels, Talon tires, foam inserts) (electric rear) (2) (TSM® rated)
$26.95
Buy Now
3671: Tires, Talon 2.8" (2)/ foam inserts (2)
$18.95
Buy Now
3672: Wheels, chrome (2.2'') (rear) (2)
$5.95
Buy Now
3674: Wheels, dyable nylon 2.2" (rear) (2)
$3.95
Order Now
Ships Late April
3691: Gearbox halves (L&R) (black) w/ idler gear shaft
$8.00
Buy Now
3691A: Gearbox halves (L&R) (grey) w/ idler gear shaft
$8.00
Buy Now
3696: Idler gear, steel (30-tooth)
$3.00
Buy Now
3739: Screw pin set (Rustler®/ Bandit/ Stampede®)
$4.50
Buy Now
3752: Stub axle carriers (2) (requires 5x11x4mm bearings)
$3.00
Buy Now
3762: Ultra Shocks (black) (xx-long) (complete w/ spring pre-load spacers & springs) (rear) (2)
$18.00
Buy Now
3762A: Ultra Shocks (grey) (xx-long) (complete w/ spring pre-load spacers & springs) (rear) (2)
$18.00
Buy Now
3772: Wheels, All-Star 2.8" (chrome) (Rustler®, Stampede® rear only)
$7.95
Notify Me
3772A: Wheels, All-Star 2.8" (black chrome) (electric rear)
$8.95
Buy Now
3785: Motor, Titan® 12T (12-Turn, 550 size)
$25.95
Buy Now
3790: Gear adapter, fixed
$4.50
Buy Now
3792: Cover, gear/ rubber gear cover plug/ 3x6 RM (2)
$3.50
Buy Now
3793: Input shaft (slipper shaft) / spring pin
$3.00
Buy Now
3934: Body clips, heavy duty (12)
$3.00
Buy Now
4628: Differential output yokes (2)/ 3x5mm countersunk screws (2)/ 3mm set (set) screws (4)
$4.00
Buy Now
4628X: Differential output yokes, hardened steel (w/ U-joints) (2)
$19.50
Buy Now
4676: Spur gear, 76-tooth (48-pitch) (for models with Torque Control slipper clutch)
$3.00
Buy Now
4683: Spur gear, 83-tooth (48-pitch) (for models with Torque Control slipper clutch)
$3.00
Buy Now
4686: Spur gear, 86-tooth (48-pitch) (for models with Torque-Control slipper clutch)
$3.00
Buy Now
4690: Spur gear, 90-tooth (48-pitch) (for models with Torque-Control slipper clutch)
$3.00
Buy Now
4914R: Body mount posts, front (2)/ body mount, rear/ body mount screw pins (4)
$6.00
Buy Now
5116: Ball bearings, blue rubber sealed (5x11x4mm) (2)
$3.50
Buy Now
5529: Shim set, 3x7x1mm (2), 3x6x0.5mm (4), 3x7x2mm (2)/ hollow balls, captured (4)
$3.50
Buy Now
5552X: Rebuild kit, slipper clutch (steel disc/ friction pads (3)/ spring (2)/ pin/ 4.0mm NL (1)/ 5.0mm NL (1))
$10.00
Notify Me
5556: Slipper pressure plate & hub (aluminum alloy)
$8.00
Buy Now
6770: Tires, Maxx® 2.8" (2)/ foam inserts (2)
$18.95
Notify Me
8361: Shock caps (black) (4) (assembled with hollow balls)
$5.00
Buy Now
Craniac (36094-1) Rear Assembly Exploded View
Print
View PDF
