TRX-4M High Range Transmission Gear Set
9776X
Boost the top end of your TRX-4M® with this high range gear set. The gear set features a high 9.7:1 reduction ratio for maximum speed. The set includes all transmission gears and a new 11-tooth motor pinion. (Not recommended for snow, mud, rock crawling, or other high-resistance surfaces)
Not recommended for snow, mud, rock crawling, or other high-resistance surfaces.
