Machined Steel Differential Ring & Pinion Gear
9579R
Made for the most extreme action, the spiral-cut 43-tooth ring and 10-tooth pinion differential gear set is CNC-machined from a solid block of steel. The teeth are cut with a slight curve to minimize backlash between gears and to maximize tooth traction with more surface area than straight-cut gears.
