22-Tooth Steel Transmission Input Gear & Shaft
$10.00
The heavy-duty input shaft features a steel 22-tooth input gear that's press-fit onto a broad flat for maximum durability and power transfer. (Use as a direct replacement for Magnum 272R™ transmissions or as an upgrade for standard Magnum 272™ transmissions)
Use as a direct replacement for Magnum 272R� transmissions or as an upgrade for standard Magnum 272� transmissions.
