Hardened Steel 30-Tooth Idler Gear w/ Shaft
$8.00
The hardened-steel 30-tooth idler gear provides maximum durability and power transfer in Magnum 272™ transmissions. Includes idler shaft. (Use as a direct replacement for Magnum 272R™ transmissions or as an upgrade for standard Magnum 272 transmissions)
Use as a direct replacement for Magnum 272R™ transmissions or as an upgrade for standard Magnum 272 transmissions.
