17 mm Gray Aluminum Splined Hubs w/ Nuts (4)
9086-GRAY
These 17 mm hex adapters make it easy to install a wide range of wheel and tire combinations on your Traxxas vehicle. The adapter's unique design maximizes contact area with 17 mm splined wheels to improve grip and prevent rounding. 17 mm splined hubs also work with traditional 17 mm hex wheels for greater compatibility. Rugged machined-aluminum construction and vivid anodized color create a custom look for your vehicle with matching aluminum nuts. Package includes 17 mm hubs (4), wheel nuts (4), hub retainers (4) and axle pins (4).
17 mm wheel hubs are designed to work with the Maxx-duty® axles used in 9080-series Extreme HD upgrade kits.
- Splined design creates more contact area with the wheel
- Compatible with traditional 17 mm non-splined wheels
- Brilliant anodized finish
- Premium quality construction with factory fit and finish
- Includes wheel nuts and hardware
- Fits Maxx-duty driveshafts with 6 mm axles only
