3.0" Gray Wheels w/ Belted Sledgehammer Tires (2)
9071-GRAY
Belted Sledgehammer® tires deliver game-changing stability and control whether you’re slinging mud or setting speed records. The wide, open-block tread design won’t clog up with dirt or debris and the lightweight belting maintains the tire’s shape for a larger contact patch, more grip, and responsive handling at any speed. The tires come mounted with foam inserts and glued to 3" gray buggy wheels with beadlock detail. Sold as a pair.
Requires 17 mm splined hex, fits front or rear.
