44-Tooth Transmission Output Gear
Use the 44-tooth transmission output gear in conjunction with the 8983 fixed gear shaft and driveshaft adapter to eliminate the center differential in the Maxx®. Eliminating the center differential applies equal power to front and rear differentials for maximum power transfer. (Eliminating the center differential requires the use of 8950X or 8996X steel CV driveshafts)
