Fixed Gear Shaft with Driveshaft Adapter
$4.00
Use the fixed gear shaft with driveshaft adapter in conjunction with the 8984 transmission output gear to eliminate the center differential in the Maxx®. Eliminating the center differential applies equal power to front and rear differentials for maximum power transfer. (Eliminating the center differential requires the use of 8950X or 8996X steel CV driveshafts)
Eliminating the center differential requires the use of 8950X or 8996X steel CV driveshafts.
