TRX-4 Traxx Complete Set
$199.95
All-terrain Traxx® with Deep-Terrain Treads provides the most significant traction upgrade you can make to the TRX-4®. The Deep-Terrain Treads dig deep and pack into loose surfaces for maximum bite to power through the most challenging conditions. The wide contact patch provides additional flotation to keep your Traxx-equipped model running strong on top of loose surfaces like deep snow and fine sand. Traxx raises the portal axles even higher (over 16 mm) for increased ground clearance that lets you straddle huge obstacles on the trail.
Pro Driving Tips
  • Use a high-output servo and High-Output BEC (2262) for maximum turning power in all conditions
  • Depending on how you use your Traxx, slight body trimming may be required
  • Use TRX-4 Long-Arm Lift Kit to minimize trimming and increase ground clearance
  • On TRX-4 models equipped with T-Locks, keep the front and rear differentials locked for optimal traction and performance
  • On TRX-4 models equipped with two-speed transmissions, always use low gear
