4-Tec Red Aluminum Turnbuckle Set
8341R
$35.95
The aluminum turnbuckle set make it easy to add strength and adjustability to your 4-Tec®. These camber and toe links come in a brilliant anodized finish for stunning good looks. Both lightweight and strong, these aluminum turnbuckles come assembled with rod ends & hollow balls. The included 5 mm aluminum wrench protects the finish while making adjustments. Includes 32 mm front camber links (2), 28 mm rear camber links (2), and 34 mm toe links (2).
