34-Gram Brass Portal Housing Weights (2)
Brass portal weights add valuable mass (34 grams) down low for improved off-road stability, without the negative effects of weighted wheels. Includes 2.5x8 mm screws (6).
Weights require aluminum outer portal housings.
WARNING: This product can expose you to chemicals including lead, which is known to the State of California to cause cancer and birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
